Trouble using LV_COLOR_FORMAT_L8 - it seems previously drawn items (e.g. label text) are not erased when they are updated or scroll and re-render. I have a custom flush callback that I have successfully working under LV_COLOR_FORMAT_I1 and LV_COLOR_DEPTH=1. My display supports grayscale so I am working to use L8 mode, but I have consistent rendering/flush problems that I have not been able to solve.
I am only testing with LV_RENDER_MODE_FULL at the moment, once that is working I will finish implementing PARTIAL in the flush cb.
Raspberry Pi Pico2, Pico SDK C++, small SPI OLED display SH1122 controller chip, 256x64 4bpp grayscale.
master from github, also tried rolling back to 9.2 with no change.
Proper rendering/flushing using L8 mode when items update.
I have confirmed using debug printf() that the data that the flush callback is receiving in the px_map buffer has the problem with prior display items not being erased. I “drew” the contents of the buffer to the serial debug port and could see the same overwriting/smearing effect on changed or scrolling labels for example. Thus, I believe it is not a problem with putting pixels onto the display but something internal to LVGL or some configuration/setup that I’m possibly missing.
My init code:
#if LV_COLOR_DEPTH == 1
#define LV_BUFSIZE ((SH1122_HOR_RES * SH1122_VER_RES / 8) + 8)
#define LV_COLOR_FORMAT LV_COLOR_FORMAT_I1
#elif LV_COLOR_DEPTH == 8
#define LV_BUFSIZE (SH1122_HOR_RES * SH1122_VER_RES)
#define LV_COLOR_FORMAT LV_COLOR_FORMAT_L8
#else
#pragma message "Unsupported color depth"
static uint8_t disp_buf1[LV_BUFSIZE];
lv_display_t* display = lv_display_create(SH1122_HOR_RES, SH1122_VER_RES);
lv_display_set_user_data(display, &oled);
lv_display_set_buffers(display, disp_buf1, NULL, sizeof(disp_buf1), LV_DISPLAY_RENDER_MODE_FULL);
lv_display_set_flush_cb(display, [](lv_display_t * display, const lv_area_t *area, uint8_t* px_map) {
OLED* oled = static_cast<OLED*>(lv_display_get_user_data(display));
oled->lv_sh1122_flush_cb(display, area, px_map);
lv_display_set_color_format (display, LV_COLOR_FORMAT);
And my flush callback:
void OLED::lv_sh1122_flush_cb(lv_display_t * display, const lv_area_t * area, uint8_t * px_map)
unsigned int xx,yy;
uint8_t* buf = px_map;
// note this only supports LV_DISPLAY_RENDER_MODE_FULL at the moment
buf += 8;
for(yy=0; yy<64; yy++)
Set_Row_Address(yy);
Set_Column_Address(0x10,0x00);
for(xx=0;xx<32;xx++)
uint8_t bv = *(buf++);
Data_processing(bv);
for(yy=area->y1; yy<area->y2+1; yy++)
Set_Column_Address(0x10, area->x1 & 0xFF);
for(xx=area->x1; xx<area->x2+1; xx+=2)
uint8_t bv1 = *(buf++) >> 4;
uint8_t bv2 = *(buf++) >> 4;
uint8_t bv = (bv1 << 4) | bv2;
Write_Data(bv);
#else
// Inform LVGL that flushing is complete so buffer can be modified again.
lv_display_flush_ready(display);
YouTube link:
working with LV_COLOR_FORMAT_I1
YouTube link:
not working with LV_COLOR_FORMAT_L8
In L8 mode, static text that I only display once and do not update or scroll works as expected with grayscale (note smooth appearance of the font):
