I am brand new to lvgl and got the simulator running with SDL2.
I am trying to simulate a small screen 240x400 with a color depth of 8 bits.
So I edited the lv_sim_vscode_sdl/ui/simulator/inc/lv_conf.h to this:
#define LV_COLOR_DEPTH 1
However that results in a segmentation fault.
rm -f ./build/bin/demo && make clean && make -j8 && ./build/bin/demo
[Warn] (0.000, +0) lv_init: Memory integrity checks are enabled via LV_USE_ASSERT_MEM_INTEGRITY which makes LVGL much slower (in lv_obj.c line #138)
[Warn] (0.000, +0) lv_init: Object sanity checks are enabled via LV_USE_ASSERT_OBJ which makes LVGL much slower (in lv_obj.c line #142)
Segmentation fault (core dumped)
I agree, the OP may have made a mistake. But setting color depth to 1 (which is my intention with the simulator for prototyping a monochrome display GUI) still causes a segfault, specifically here:
Hmm, seems to be writing into a wrong memory location.
A mismatch of buffer sizes? As far as I can see, a color depth of 1 also needs one byte per pixel on lvgl side
Is there something else that needs modification for the LVGL simulator to run properly with 1-bit color depth? The same problem occurs when I try to set color depth to 8. I’m running the simulator on Ubuntu 22.04. The only changes I have made to the original repo are:
Changed LV_COLOR_DEPTH to 1 in lv_conf.h
Changed LV_BUILD_EXAMPLES to 0 in lv_conf.h
Commented out lv_demo_widgets() from main.c
Added a “Hello world” label in main.c to be displayed
This was indeed a buffer problem. The hal init function in main doesn’t account for color depth selection when setting the draw buffer, so any color depth value besides 32 results in a segfault. I can open a PR with a proposed fix, but I don’t know if this was intentionally left as-is and would prefer to not embarrass myself on GitHub if that’s the case.
