v 9.0.0
I am noticing an issue with X axis ticks not appearing. The Y axis works absolutely alright for me. The lvgl chart type I am using is none and I am using setting the data range for the x axis as 0 to 50000
This is a small snippet of my code -
/* Create a pl_gui_fft_chart for displaying axises (not for actual data display) */
chart = lv_chart_create(parent);
lv_chart_set_type(chart, LV_CHART_TYPE_NONE);
lv_obj_set_size(chart, 600, 340);
lv_obj_set_pos(chart, 30, 50);
lv_chart_set_range(chart,
LV_CHART_AXIS_PRIMARY_X,
0,
25000);
lv_chart_set_axis_tick(chart,
5,
0,
10,
1,
true,
50);
/* Display labels on x and y axises */
LV_CHART_AXIS_PRIMARY_Y,
5,
0,
9,
1,
true,
100);
/* Set the x and y axises range (input data range) */
-200,
0);
lv_chart_refresh(chart);
This same snippet however works if the chart type is changed to Scatter. Have checked with the simulator as well and the x axis ticks are coming as 0 1 2 3 4 and so on
import lvgl as lv
import display_driver
# Initialize LVGL
lv.init()
# Create a screen object
scr = lv.obj()
# Create a chart object
chart = lv.chart(scr)
chart.set_size(600, 340)
chart.set_pos(30, 50)
chart.set_type(lv.chart.TYPE.NONE) # Set chart type to NONE
# Set the X and Y axis ranges
chart.set_range(lv.chart.AXIS.PRIMARY_X, 0, 50000)
chart.set_range(lv.chart.AXIS.PRIMARY_Y, -200, 0)
# Set axis ticks (this may need adjustments)
chart.set_axis_tick(lv.chart.AXIS.PRIMARY_X, 5, 0, 10, 1, True, 50)
chart.set_axis_tick(lv.chart.AXIS.PRIMARY_Y, 5, 0, 9, 1, True, 100)
# Add a dummy series to trigger X-axis scaling
dummy_ser = chart.add_series(lv.color_hex(0xFF0000), lv.chart.AXIS.PRIMARY_Y)
chart.set_next_value(dummy_ser, 0)
chart.set_next_value(dummy_ser, 50000)
# Force refresh
chart.invalidate()
# Load the screen
lv.scr_load(scr)
This is a SS from the simulator
