LV_CHART question
Question about LV_CHART (bar spacing, axis titles…)
ESP32S3 with Platformio
9.2
In my current project I am using LV_CHART to display a bar chart with the SNR level of GPS satellites.
Something like this:
snr
My questions are the following:
  • Is it possible to modify the gap between the bars, making there is no separation between them?
  • When adapting the widget to lower resolution screens (changing the widget width), it currently changes the width of the bars making them smaller. Is it still possible to change the size of the widgets, keeping bars size like the image?
  • On the other hand, I am now doing a “trick” to put a title on the X axis (using a LovyanGfx sprite). Is it possible to this title inside the bar in vertical format?
Thank you!
Interestingly enough, I was migrating code this weekend from LVGL 8->9 to do a similar task (LVGL bar chart showing satellite cno and other status info). Here’s a screenshot:
Briefly, you can set the chart padding to alter the bar width / spacing. This is what I have:
  //Padding of chart
  lv_obj_set_style_pad_all(gnss_chtSignal, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
  //Padding to make series bars wider
  lv_obj_set_style_pad_gap(gnss_chtSignal, -7, LV_PART_ITEMS | LV_STATE_DEFAULT);
Then this is where it gets a little tricky, at least for me - LVGL has a lot of good stuff for overriding widget draw events, but the written documentation is virtually non-existent, you have to rely on example code as documentation and, sadly, some of those examples have bugs in them, such as incorrect typing of variables that co-incidentally work for the example, but not if you expand upon them… I can give you pointers and share my working code, but I’m still figuring it all out too, so it may not be optimal and I may not be able to provide more info :slight_smile:
I enhance the chart with the following -
  • Color of the bar, showing which GNSS it belongs to
  • Border color of bar, indicating if the satellite is in-use for the fix (white), or not (black)
  • CNO displayed at the top of the bar
  • Circles indicating if the ephemeris and almanac data have been downloaded (green) or not (red)
  • Satellite vehicle ID added to the bottom part of the bar (needs some more work)
I add these events to my chart:
lv_obj_add_event_cb(gnss_chtSignal, gnss_chtSignal_draw_event_cb, LV_EVENT_DRAW_TASK_ADDED, NULL);
lv_obj_add_event_cb(gnss_chtSignal, gnss_chtSignal_draw_event_cb, LV_EVENT_DRAW_POST_END, NULL);
lv_obj_add_flag(gnss_chtSignal, LV_OBJ_FLAG_SEND_DRAW_TASK_EVENTS);
and then implement the callback like this:
void gnss_chtSignal_draw_event_cb(lv_event_t * e)
  lv_event_code_t event = lv_event_get_code(e);
  lv_obj_t * obj = (lv_obj_t *)lv_event_get_target(e);
  if (event == LV_EVENT_DRAW_TASK_ADDED) {
    lv_draw_task_t * draw_task = lv_event_get_draw_task(e);
    lv_draw_dsc_base_t * base_dsc = (lv_draw_dsc_base_t *)lv_draw_task_get_draw_dsc(draw_task);
    if(base_dsc->part == LV_PART_ITEMS) {
      uint16_t dscId = base_dsc->id2;
      if (gnss_svInfo[dscId].cno > 0) {
        //Change color/border of bar depending on GNSS and if SV is in use
        if (lv_draw_task_get_type(draw_task) == LV_DRAW_TASK_TYPE_FILL) {
          lv_draw_fill_dsc_t * fill_dsc = lv_draw_task_get_fill_dsc(draw_task);
          if(fill_dsc) {
            fill_dsc->color = lv_palette_main(gnss_color[gnss_svInfo[dscId].gnssId]);
        if (lv_draw_task_get_type(draw_task) == LV_DRAW_TASK_TYPE_BORDER) {
          lv_draw_border_dsc_t * border_dsc = lv_draw_task_get_border_dsc(draw_task);
          if (border_dsc) {
            border_dsc->width = gnss_svInfo[dscId].bInUse == true ? 1 : 0;
            border_dsc->color = gnss_svInfo[dscId].bInUse == true ? lv_color_white() : lv_color_black();
  if (event == LV_EVENT_DRAW_POST_END) {
    lv_layer_t * layer = lv_event_get_layer(e);
    const char sensorDotBuf[4] = "●";
    char buf[16];
    for (uint16_t i=0; i<ARRAY_SIZE(gnss_svInfo); i++) {
      if (gnss_svInfo[i].cno > 0) {
        lv_area_t chart_obj_coords;
        lv_obj_get_coords(obj, &chart_obj_coords);
        lv_point_t p;
        lv_chart_get_point_pos_by_id(obj, lv_chart_get_series_next(obj, NULL), i, &p);
        //Draw signal at top of bar
        lv_snprintf(buf, sizeof(buf), LV_SYMBOL_DUMMY"%d", gnss_svInfo[i].cno);
        drawTextOnLayer(buf, layer, &p, &chart_obj_coords, lv_color_white(), lv_fontTiny, 15);
        lv_snprintf(buf, sizeof(buf), LV_SYMBOL_DUMMY"%s", sensorDotBuf);
        //Draw circle below top of bar to represent ephemeris status
        drawTextOnLayer(buf, layer, &p, &chart_obj_coords, gnss_svInfo[i].bEphAvail == true ? okStatusColorLV : errorStatusColorLV, lv_sensorDotFont, -10);
        //Draw circle below top of bar to represent almanac status
        drawTextOnLayer(buf, layer, &p, &chart_obj_coords, gnss_svInfo[i].bAlmAvail == true ? okStatusColorLV : errorStatusColorLV, lv_sensorDotFont, -22);
        //Draw SVID in bar
        lv_snprintf(buf, sizeof(buf), LV_SYMBOL_DUMMY"%d", gnss_svInfo[i].svId);
        drawTextOnLayer(buf, layer, &p, &chart_obj_coords, lv_color_white(), lv_fontSmall, (chart_obj_coords.y1 + p.y) - chart_obj_coords.y2 + 10);
void drawTextOnLayer(const char * text, lv_layer_t * layer, lv_point_t * p, lv_area_t * coords, lv_color_t color, const void * font, int16_t offset)
  lv_draw_rect_dsc_t draw_rect_dsc;
  lv_draw_rect_dsc_init(&draw_rect_dsc);
  //draw_rect_dsc.bg_color = lv_color_black();
  draw_rect_dsc.bg_opa = LV_OPA_TRANSP;
  draw_rect_dsc.radius = 0;
  draw_rect_dsc.bg_image_symbol_font = font;
  draw_rect_dsc.bg_image_src = text;
  draw_rect_dsc.bg_image_recolor = color;
  lv_area_t a;
  a.x1 = coords->x1 + p->x - 10;
  a.x2 = coords->x1 + p->x + 10;
  a.y1 = coords->y1 + p->y + 10 - offset;
  a.y2 = a.y1 - 20;
  lv_draw_rect(layer, &draw_rect_dsc, &a);
Pick that apart and hope it helps :slight_smile: I also use an lv_chart scatter chart to show satellite positions in the sky. I think it works:
Cool!
I’ll try it! thank you!
Can I use a little of your code to test it?
Which code do you mean? Anything I post here, you’re welcome to use at will! Beyond that, behind that snippet of code for the draw callbacks, there is, for example, extensive code to populate the gnss_svInfo array with data, using libraries to read my sat receiver, etc. and other such code that isn’t easy to break out into something you can install and run ‘out of the box’.
I assumed you already had a working chart, and satellite data for that chart, which you could then adapt the posted code to your needs? Happy to provide other snippets, but I couldn’t provide a full working app, it’s too specific/embedded to my custom hardware/full working app.
No, no, sorry I explained myself badly, I was asking if I could use the code snippet you posted as an example.
I’ve my own code that read my sat receiver, etc…
Sorry for my bad English
No worries! Absolutely, go ahead and use it as you wish, that is what the forum is for! If you have any further questions or need more info, ask away!
Thank you!
I’m working in it
