Lv_chart connect points
When using lv_chart with type LV_CHART_TYPE_LINE, I would like to be able to have it to connect points, even if there are empty points between, that are not set.
Tried to do the interpolation, when receiving samples, but am I the only that need this?
LVGL PC simulator v9.3
Hi @Frank_Andersen ,
The lv_chart do not explicitly mention a option to automatically skip over LV_CHART_POINT_NONE values and connect the surrounding valid points in LV_CHART_TYPE_LINE
I’m suggest to use lv_chart_set_point_count with only valid points.
