I have this graphical interface but at the moment when the RPM needle increases or moves it generates low fps! Any way to manage memory? so you can increase an acceptable number! I have tried with lv_conf but no luck!
ESP32-S3 HMI 8M PSRAM 16M Flash Arduino LVGL WIFI&Bluetooth 5 " IPS 800*480
From AliExpress
8.3.6
Better FPS
Mod custom mem on lv_conf
MEMORY SETTINGS
/1: use custom malloc/free, 0: use the built-in lv_mem_alloc() and lv_mem_free()/
#define LV_MEM_CUSTOM 1
#if LV_MEM_CUSTOM == 0
/Size of the memory available for lv_mem_alloc() in bytes (>= 2kB)/
#define LV_MEM_SIZE (256U * 1024U) /[bytes]/
#if LV_MEM_ADR == 0
#undef LV_MEM_POOL_INCLUDE
#undef LV_MEM_POOL_ALLOC
#else /LV_MEM_CUSTOM/
#define LV_MEM_CUSTOM_INCLUDE <stdlib.h> /Header for the dynamic memory function/
#define LV_MEM_CUSTOM_ALLOC malloc
#define LV_MEM_CUSTOM_FREE free
#define LV_MEM_CUSTOM_REALLOC realloc
#endif /LV_MEM_CUSTOM/
/*Number of the intermediate memory buffer used during rendering and other internal processing mechanisms.
*You will see an error log message if there wasn’t enough buffers. */
#define LV_MEM_BUF_MAX_NUM 16
/Use the standard memcpy and memset instead of LVGL’s own functions. (Might or might not be faster)./
#define LV_MEMCPY_MEMSET_STD 0
here is a video with the problem
Video Low FPS
