Hi!
It seems on ESP32 port the lodepng library is still not using the custom (MicroPython) memory allocation function from mp_lodepng.c file, instead it uses the old malloc(), and that throws a memory allocation error.
Although the LODEPNG_NO_COMPILE_ALLOCATORS is defined in lv_bindings/mkrules.cmake file, the compiled lodepng.cpp file is still using malloc().
Could you please check it on your M5Core2 device (or other device)?
Thank you!
Repro steps:
Add following line to
lv_bindings/driver/png/lodepng/lodepng.cppfile line#78(insidelodepng_malloc()function):
printf("* LODEPNG-OLD-malloc *"); -
lv_bindings/driver/png/mp_lodepng.cfile line line#11(insidelodepng_malloc()function):
printf("* LODEPNG-NEW-malloc *"); -
Download attached test app (see below:
png-test.zip) to your Linux dev environment -
Edit, then run
run-linux-simulator.shscript
Result:LODEPNG-NEW-malloctext is shown in console, and PNG image is shown inTFT Simulatorwindow -
Edit, then run
run-m5core2.shscript
Result:LODEPNG-OLD-malloctext is shown, no image on device, and there is also an error message:lodepng_error: memory allocation failed
png-test.zip (11.7 KB)
