How to load png image from SD Card?
ESP32 S3 - Waveshare 7 Inch display
8.3.11
Load images from SD Card to recude RAM/Flash Usage.
I tried many many ways… At this moment I mounted correctly SD card on start application. In button press event function i have function to read png files.
#include "ui.h"
#include "esp_heap_caps.h"
#include "esp_log.h"
#include "esp_vfs_fat.h"
#include "sdmmc_cmd.h"
#include "sd_test_io.h"
#include "dirent.h"
int counter = 1;
#define MOUNT_POINT "/sdcard"
static const char *SDTAG = "SDLOG";\
void list_files_on_sd_card2() {
DIR *dir = opendir(MOUNT_POINT); // open main folder on SD Card
if (dir == NULL) {
ESP_LOGE(SDTAG, "Failed to open directory");
return;
struct dirent *entry;
while ((entry = readdir(dir)) != NULL) {
ESP_LOGI(SDTAG, "Found file: %s", entry->d_name); // Write full file path
closedir(dir); // close folder
static esp_err_t read_binary_file(const char *path) {
ESP_LOGI(SDTAG, "Reading binary file: %s", path);
size_t free_psram = heap_caps_get_free_size(MALLOC_CAP_SPIRAM);
ESP_LOGI("PSRAM", "1 PSRAM Free Heap: %d, w MB: %.2f", free_psram, (float)free_psram / 1048576);
FILE *f = fopen(path, "rb");
if (f == NULL) {
ESP_LOGE(SDTAG, "Failed to open file for reading");
return ESP_FAIL;
// check png file size
fseek(f, 0, SEEK_END); // Przesuń wskaźnik na koniec pliku
long file_size = ftell(f); // Zapisz rozmiar pliku
fseek(f, 0, SEEK_SET); // Przesuń wskaźnik z powrotem na początek pliku
ESP_LOGI(SDTAG, "File size: %ld bytes", file_size);
uint8_t *buffer = (uint8_t *)malloc(file_size);
if (buffer == NULL) {
ESP_LOGE(SDTAG, "Failed to allocate memory for image");
fclose(f);
return ESP_ERR_NO_MEM;
ESP_LOGI("PSRAM", "2 PSRAM Free Heap: %d, w MB: %.2f", free_psram, (float)free_psram / 1048576);
/*size_t bytes_read;
while ((bytes_read = fread(buffer, 1, sizeof(buffer), f)) > 0) {
ESP_LOGI(SDTAG, "Read %d bytes", bytes_read);
// Przetwórz dane w buforze
// read png file to buffer
size_t bytes_read = fread(buffer, 1, file_size, f);
if (bytes_read != file_size) {
ESP_LOGE(SDTAG, "Failed to read entire file");
free(buffer);
fclose(f);
return ESP_FAIL;
fclose(f);
// image struct of lvgl
lv_img_dsc_t img_dsc = {0};
img_dsc.data = buffer;
img_dsc.header.cf = LV_IMG_CF_TRUE_COLOR_ALPHA;
img_dsc.header.always_zero = 0;
img_dsc.header.w = 0;
img_dsc.header.h = 0;
lv_img_set_src(ui_Image1, &img_dsc); // z tym 5.22
free(buffer);
ESP_LOGI(SDTAG, "PNG image loaded successfully");
return ESP_OK;
void changeIMG(lv_event_t * e)
counter++;
ESP_LOGI("PSRAM", " Przed PSRAM Free Heap: %d, w MB: %.2f", free_psram, (float)free_psram / 1048576);
//list_files_on_sd_card2();
//read_binary_file("/sdcard/001.png");
if(counter > 4){
counter = 1;
switch(counter){
case 1:
lv_img_set_src(ui_Image1, &ui_img_1_png); // z tym 5.66
ESP_LOGI("IMG1", "buffer: %d", &ui_img_1_png.data);
break;
case 2:
//lv_img_set_src(ui_Image1, &ui_img_2_png); // z tym 5.22
break;
case 3:
//lv_img_set_src(ui_Image1, &ui_img_3_png); // z tym 4.72
read_binary_file("/sdcard/002.png");
break;
case 4:
read_binary_file("/sdcard/003.png");
//lv_img_set_src(ui_Image1, &ui_img_4_png); // z tym 4.28
break;
ESP_LOGI("PSRAM", " Po PSRAM Free Heap: %d, w MB: %.2f", free_psram, (float)free_psram / 1048576);
