I tried switching between screens with lv_scr_load_anim(), but it loads with low rendering speed. I have tried optimizing SPI Frequency and prj.conf, still no difference.
MCU: nRF52832
Display: 240x240 ST7789 and CST816S
Platform: Zephyr with nRF Connect
8.4.0
Smooth screen transition animations
Optimized SPI speed frequency and LV memory size
main code:
void switch_to_screen(int screen_index, lv_scr_load_anim_t anim)
uint64_t screen_count = sizeof(create_screens) / sizeof(create_screens[0]);
if (screen_index < 0 || screen_index >= screen_count)
LOG_ERR("Invalid screen number: %d", screen_index);
return;
lv_obj_t *screen = create_screens[screen_index]();
if (screen == NULL)
LOG_ERR("Failed to create screen %d", screen_index);
return;
lv_scr_load_anim(screen, anim, DISPLAY_ANIMATION_TIME, DISPLAY_ANIMATION_DELAY, true);
current_screen = screen;
static void handle_screen_gesture(lv_dir_t dir)
lv_scr_load_anim_t anim = LV_SCR_LOAD_ANIM_NONE;
if (dir == LV_DIR_TOP)
current_screen_index++;
if (current_screen_index > screen_count - 1)
current_screen_index = 0;
anim = LV_SCR_LOAD_ANIM_MOVE_TOP;
else if (dir == LV_DIR_BOTTOM)
current_screen_index--;
if (current_screen_index < 0)
current_screen_index = screen_count - 1;
anim = LV_SCR_LOAD_ANIM_MOVE_BOTTOM;
else if (dir == LV_DIR_RIGHT && current_screen_index != 0)
switch_to_screen(current_screen_index, anim);
return;
LOG_WRN("Unknown gesture direction: %d", dir);
return;
last_screen_index = current_screen_index;
static void on_lvgl_screen_gesture_event_callback(lv_event_t *e)
lv_dir_t dir;
if (code == LV_EVENT_GESTURE)
dir = lv_indev_get_gesture_dir(lv_indev_get_act());
if (dir == LV_DIR_TOP || dir == LV_DIR_BOTTOM || dir == LV_DIR_RIGHT)
if (change_to_others_screen)
handle_others_screen_gesture(dir);
handle_screen_gesture(dir);
else if (code == LV_EVENT_CLICKED)
uint32_t screen_count = sizeof(create_screens) / sizeof(create_screens[0]);
if (last_screen_index == screen_count - 1)
if (!change_to_others_screen)
change_to_others_screen = true;
current_others_screen_index = 0;
k_msleep(DISPLAY_ANIMATION_DELAY);
switch_to_others_screen(current_others_screen_index, LV_SCR_LOAD_ANIM_NONE);
LOG_WRN("Unknown event code: %d", code);
lv_indev_wait_release(lv_indev_get_act());
lv_obj_t *create_screen0()
lv_obj_t *screen = lv_obj_create(NULL);
lv_obj_set_style_bg_color(screen, lv_color_hex(0x000033), LV_PART_MAIN);
lv_obj_t *label = lv_label_create(screen);
lv_label_set_text(label, "Screen 0: Welcome!");
lv_obj_set_style_text_color(label, lv_color_white(), LV_PART_MAIN);
lv_obj_set_style_text_font(label, &lv_font_montserrat_22, LV_PART_MAIN);
lv_obj_add_event_cb(screen, on_lvgl_screen_gesture_event_callback, LV_EVENT_GESTURE, NULL);
return screen;
lv_obj_t *create_screen1()
lv_obj_set_style_bg_color(screen, lv_color_hex(0x003366), LV_PART_MAIN);
lv_label_set_text(label, "Screen 1: Hello!");
return screen;
Board overlay:
chosen {
zephyr,display = &display;
aliases {
input = &touch_screen;
leds {
compatible = "gpio-leds";
lcd_backlight: lcd_backlight {
gpios = <&gpio0 11 GPIO_ACTIVE_LOW>;
label = "LCD Backlight";
lvgl_pointer_input:lvgl_pointer {
compatible = "zephyr,lvgl-pointer-input";
input = <&touch_screen>;
&spi0 {
compatible = "nordic,nrf-spim";
display: st7789v@0 {
label = "ST7789 Display";
compatible = "sitronix,st7789v";
spi-max-frequency = <DT_FREQ_M(32)>;
reg = <0>;
cmd-data-gpios = < &gpio0 27 GPIO_ACTIVE_LOW>;
reset-gpios = < &gpio0 31 GPIO_ACTIVE_LOW>;
width = <240>;
height = <240>;
x-offset = <0>;
y-offset = <0>;
vcom = <0x19>;
gctrl = <0x35>;
vrhs = <0x12>;
vdvs = <0x20>;
mdac = <0x00>;
gamma = <0x01>;
colmod = <0x05>;
lcm = <0x2c>;
porch-param = [0c 0c 00 33 33];
cmd2en-param = [5a 69 02 01];
pwctrl1-param = [a4 a1];
pvgam-param = [D0 04 0D 11 13 2B 3F 54 4C 18 0D 0B 1F 23];
nvgam-param = [D0 04 0C 11 13 2C 3F 44 51 2F 1F 1F 20 23];
ram-param = [00 F0];
rgb-param = [CD 08 14];
&i2c1 {
touch_screen: cst186s@15 {
label = "CST816S";
compatible = "hynitron,cst816s";
reg = <0x15>;
irq-gpios = <&gpio0 26 GPIO_ACTIVE_LOW>;
rst-gpios = <&gpio0 21 GPIO_ACTIVE_LOW>;
prj.conf
CONFIG_LOG=y
CONFIG_SHELL=y
CONFIG_THREAD_STACK_INFO=y
CONFIG_MAIN_STACK_SIZE=2048
CONFIG_DISPLAY=y
CONFIG_DISPLAY_LOG_LEVEL_ERR=y
CONFIG_LVGL=y
CONFIG_LV_Z_MEM_POOL_SIZE=8192
CONFIG_LV_Z_SHELL=y
CONFIG_LV_MEM_CUSTOM=y
CONFIG_LV_USE_LOG=y
CONFIG_LV_USE_LABEL=y
CONFIG_LV_FONT_MONTSERRAT_22=y
CONFIG_LV_Z_POINTER_INPUT=y
CONFIG_INPUT=y
CONFIG_INPUT_CST816S=y
CONFIG_INPUT_CST816S_INTERRUPT=y
CONFIG_SOC_NRF52832_ALLOW_SPIM_DESPITE_PAN_58=y
