Loading an Image from the TF Card so that it is displayed on the screen
Waveshare ESP32-S3-Touch-LCD-5; TF-Card Slot is directly on the board ; Arduino IDE
Displaying an Image, which is stored as C-Array on the ESP32. → worked
But because the storage is maxxed out, i tried to extend the Waveshare SD Card Demo project. But this didn’t work. Even Chatgpt couldn’t solve my problem.
I would be so grateful if sombody would help me or even has a code for me which work
This is the original demo project for a sd card.
When i compile this one, i can see the txt files on the computer when I insert the sd card.
#include "waveshare_sd_card.h"
// Initial Setup
void setup(){
    Serial.begin(115200);
    Serial.println("Initialize IO expander");
    /* Initialize IO expander */
    ESP_IOExpander *expander = new ESP_IOExpander_CH422G((i2c_port_t)I2C_MASTER_NUM, ESP_IO_EXPANDER_I2C_CH422G_ADDRESS, I2C_MASTER_SCL_IO, I2C_MASTER_SDA_IO);
    expander->init();
    expander->begin();
    expander->multiPinMode(TP_RST | LCD_BL | LCD_RST | SD_CS | USB_SEL, OUTPUT);
    expander->multiDigitalWrite(TP_RST | LCD_BL | LCD_RST, HIGH);
    // Use extended GPIO for SD card
    expander->digitalWrite(SD_CS, LOW);
    // Turn off backlight
    expander->digitalWrite(LCD_BL, LOW);
    // When USB_SEL is HIGH, it enables FSUSB42UMX chip and gpio19, gpio20 wired CAN_TX CAN_RX, and then don't use USB Function
    expander->digitalWrite(USB_SEL, LOW);
    // Initialize SPI
    SPI.setHwCs(false);
    SPI.begin(SD_CLK, SD_MISO, SD_MOSI, SD_SS);
    if (!SD.begin()) {
        Serial.println("Card Mount Failed"); // SD card mounting failed
        return;
    uint8_t cardType = SD.cardType();
    if (cardType == CARD_NONE) {
        Serial.println("No SD card attached"); // No SD card connected
        return;
    Serial.print("SD Card Type: "); // SD card type
    if (cardType == CARD_MMC) {
        Serial.println("MMC");
    } else if (cardType == CARD_SD) {
        Serial.println("SDSC");
    } else if (cardType == CARD_SDHC) {
        Serial.println("SDHC");
    } else {
        Serial.println("UNKNOWN"); // Unknown Type
    uint64_t cardSize = SD.cardSize() / (1024 * 1024);
    Serial.printf("SD Card Size: %lluMB\n", cardSize); // SD card size
    // Testing file system functionality
    listDir(SD, "/", 0);
    createDir(SD, "/mydir");
    removeDir(SD, "/mydir");
    listDir(SD, "/", 2);
    writeFile(SD, "/hello.txt", "Hello ");
    appendFile(SD, "/hello.txt", "World!\n");
    readFile(SD, "/hello.txt");
    deleteFile(SD, "/foo.txt");
    renameFile(SD, "/hello.txt", "/foo.txt");
    readFile(SD, "/foo.txt");
    testFileIO(SD, "/test.txt");
    Serial.printf("Total space: %lluMB\n", SD.totalBytes() / (1024 * 1024)); // Total space
    Serial.printf("Used space: %lluMB\n", SD.usedBytes() / (1024 * 1024)); // Used space
// Main Loop
void loop() {
This is the waveshare_sd_card.h:
#ifndef __SD_CARD_H
#define __SD_CARD_H
#include "FS.h"
#include "SD.h"
#include "SPI.h"
#include <ESP_IOExpander_Library.h>
// Extension IO pin definition
#define TP_RST 1      // Touch screen reset pin
#define LCD_BL 2      // LCD backlight pinout
#define LCD_RST 3     // LCD reset pin
#define SD_CS 4       // SD card select pin
#define USB_SEL 5     // USB select pin
// I2C pin definitions
#define I2C_MASTER_NUM I2C_NUM_0    // I2C Master Number
#define I2C_MASTER_SDA_IO 8         // I2C data line pins
#define I2C_MASTER_SCL_IO 9         // I2C clock line pin
#define SD_MOSI 11    // SD card master output slave input pin
#define SD_CLK  12    // SD card clock pin
#define SD_MISO 13    // SD card master input slave output pin
#define SD_SS -1      // SD card select pin (not used)
void listDir(fs::FS &fs, const char * dirname, uint8_t levels);
void createDir(fs::FS &fs, const char * path);
void removeDir(fs::FS &fs, const char * path);
void writeFile(fs::FS &fs, const char * path, const char * message);
void appendFile(fs::FS &fs, const char * path, const char * message);
void readFile(fs::FS &fs, const char * path);
void deleteFile(fs::FS &fs, const char * path);
void renameFile(fs::FS &fs, const char * path1, const char * path2);
void testFileIO(fs::FS &fs, const char * path);
