Load PNG data into memory and display
I’d like to be able to draw a png to the display from a plain pixel array. I am using lodepng (specifically lodepng_decode32_file) to put the decoded png into memory and creating a lv_img_dsc_t variable to pass to lv_image_set_src. It is somewhat working (image displays but it is very distorted) but there seems to be an issue with the colour format and I may be missing some post processing that needs to be done before passing the buffer to lvgl.
v9.1
unsigned char* png_decoded;
    unsigned w;
    unsigned h;
    lodepng_decode32_file(&png_decoded, &w, &h, "A:/path/to/image.png");
    static lv_img_dsc_t png_dsc =
            .header = {
                .magic = LV_IMAGE_HEADER_MAGIC,
                .cf = LV_COLOR_FORMAT_RGB565A8,
                .w = w,
                .h = h,
            .data_size = w * h * 3,
            .data = png_decoded};
    lv_image_set_src(lv_image_create(lv_screen_active()), &png_dsc);
I have used the image converter and it is displaying fine but this is not my use case. I’m using a png file as the source of the png buffer for testing. Here is a screenshot of the distorted image:
Screenshot from 2024-09-30 16-35-58
Let me know if you need any more info
I have a working implementation now with the following updated code:
    lv_draw_buf_t* decoded = nullptr;
    uint32_t width, height;
    lodepng_decode32_file((unsigned char**)&decoded, &width, &height, "A:/path/to/image.png");
            .header = {
                .cf = LV_COLOR_FORMAT_ARGB8888,
                .w = w,
                .h = h,
            .data_size = width * height * 4,
            .data = decoded->data};
It still feels like I am not implementing this correctly, I was hoping the built in png decoder functions would be called when lv_image_set_src is called. Anybody any ideas how I can utilise the existing png decoder when loading an image from memory and not a file?
@embeddedt @kisvegabor I was wondering if you had any ideas on this?
Updated code below for decoding from memory instead of file:
    lodepng_decode32((unsigned char**)&decoded, &width, &height, png_data);
            .header = {
                .w = width,
                .h = height,
I think the safest and the least hacky way of doing it is rendering to a canvas and keeping the buffer. See lv_example_canvas_6 as a reference.
