Load images into cache before displaying (ESP32 + SPIFFS fs +.bin converted image)
I have been able ta create a filesystem based on the stdio one and load a .bin image into the system. Previously i have been doing it with .c converted files including them into the program but I had to add more images recently and the program upload times and increased a lot.
That’s why I made a partition to upload images with a SPIFFS filesystem and I´m able to load them into the screen but the time to complete draw the image into the display has increased a lot. I think that the solution is in using _lv_img_cache_open but I didn’t find any example of how to do it.
ESP32-S3 with ESP-IDF4.4.3
LVGL 8.2
Faster upload to display or caching the image before showing them.
use of _lv_img_cache_open but to no avail.
Display image:
void showLogo(void)
    Logo_page = lv_obj_create(NULL);
	AdvanticsysLogo_img = lv_img_create(Logo_page); // this is where we create the container to hold the image
	//lv_color_t color = lv_color_make(255, 255, 255);
	//_lv_img_cache_open("F:images/HelloWorld.bin",color, 1);
	lv_img_set_src(AdvanticsysLogo_img, "F:images/HelloWorld.bin"); // this is where we give the source of the image to the container
	lv_scr_load(Logo_page);
Filesystem
static void * fs_open(lv_fs_drv_t * drv, const char * path, lv_fs_mode_t mode)
    LV_UNUSED(drv);
    const char * flags = "";
    if(mode == LV_FS_MODE_WR) flags = "wb";
    else if(mode == LV_FS_MODE_RD) flags = "rb";
    else if(mode == (LV_FS_MODE_WR | LV_FS_MODE_RD)) flags = "rb+";
    /*Make the path relative to the current directory (the projects root folder)*/
    char buf[256];
	char complete_path[strlen(path) + 1];
    complete_path[0] = '/';
    complete_path[1] = '\0';
    strcat(complete_path, path);
    return fopen(complete_path, flags);
static lv_fs_res_t fs_read(lv_fs_drv_t * drv, void * file_p, void * buf, uint32_t btr, uint32_t * br)
    LV_UNUSED(drv);
    *br = fread(buf, 1, btr, file_p);
    return (int32_t)(*br) < 0 ? LV_FS_RES_UNKNOWN : LV_FS_RES_OK;
static lv_fs_res_t fs_close(lv_fs_drv_t * drv, void * file_p)
    LV_UNUSED(drv);
    fclose(file_p);
    return LV_FS_RES_OK;
static lv_fs_res_t fs_seek(lv_fs_drv_t * drv, void * file_p, uint32_t pos, lv_fs_whence_t whence)
    LV_UNUSED(drv);
    fseek(file_p, pos, whence);
static lv_fs_res_t fs_tell(lv_fs_drv_t * drv, void * file_p, uint32_t * pos_p)
    LV_UNUSED(drv);
    *pos_p = ftell(file_p);
esp_err_t spiffs_driver_init(void)
   	esp_vfs_spiffs_conf_t conf1 = {
      .base_path = "/images",
      .partition_label = "images",
      .max_files = 100,
      .format_if_mount_failed = true
    ESP_LOGW(TAG, "MOUNTING FILESYSTEM IN IMAGE");
    esp_err_t ret = esp_vfs_spiffs_register(&conf1);
    if (ret != ESP_OK)
        if (ret == ESP_FAIL)
            ESP_LOGE(TAG, "Failed to mount or format filesystem");
        else if (ret == ESP_ERR_NOT_FOUND)
            ESP_LOGE(TAG, "Failed to find SPIFFS partition");
            ESP_LOGE(TAG, "Failed to initialize SPIFFS (%s)", esp_err_to_name(ret));
        return ESP_FAIL;
    size_t total = 0, used = 0;
    ret = esp_spiffs_info(conf1.partition_label, &total, &used);
    if (ret != ESP_OK)
        ESP_LOGE(TAG, "Failed to get SPIFFS partition information (%s)", esp_err_to_name(ret));
        ESP_LOGI(TAG, "MOUNT IMAGE OK: Partition size: total: %d, used: %d", total, used);
	static lv_fs_drv_t drv; /*A driver descriptor*/
    lv_fs_drv_init(&drv);
    drv.letter = 'F';
    drv.open_cb = fs_open;
    drv.read_cb = fs_read;
    drv.close_cb = fs_close;
	drv.seek_cb = fs_seek;
    drv.tell_cb = fs_tell;
    drv.dir_open_cb = NULL;
    drv.dir_read_cb = NULL;
    drv.dir_close_cb = NULL;
    lv_fs_drv_register(&drv);
    ESP_LOGW(TAG, "FINISHING MOUNTING IMAGE FILESYSTEM ");
    return ESP_OK;
any idea?
hello, i also want to display bin images that i have stored on the esp32 with spiffs and i would like to display them on the screen with lvgl. I am not too concerned with speed yet, i would just like to display the image, any guidance is welcomed
