I am totally new to Micropython.
I would like to use LittlevGL with the Thonny IDE.
The target hardware is a ST Nucleo board (STM32F401) which I can make running with Micropython and the Thonny IDE.
My problem is that I really couldn’t understand at all how to add LittlevGL to the Thonny project file system.
In short, I would need to know exactly how to be able to get the following instruction working within the Thonny IDE:
import lvgl as lv
I always get the error message: ImportError: no module named ‘lvgl’
If someone could help me with a detailed and understandable step by step instruction I would appreciate it very much.
Additionally, it would be great if someone could also tell me what I need to modify within the code to make a 2.8" display with ILI9341 driver running on the STM32F401 target system (with parallel or with SPI interface).
Hi @aklein9999!
I know nothing about Thonny IDE.
I assume this is a Python editor, probably with nice integration of Debugger, Build System etc.
The important thing you need to understand is that LittlevGL and its Micropython binding are C Projects, not Python projects. Think of them as an extension to the MicroPython core libraries (lvgl is a “native” python module).
In order to make “import lvgl as lv” work, you first need to build Micropython with lvgl binding on your machine, specifically the stm32 port. I believe that Thonny will not help you with this. You need to have some understanding of C code and how to build C with GNU Make.
Micropython LittlevGL binding can work in principle with any embedded architecture and display hardware, but each architecture and hardware requires porting.
I ported (and maintaining):
The unix port that can be used on any Linux device with either SDL or FrameBuffer
ESP32 port with ILI9341
There has been attempts to port it to other architectures and hardware, but unfortunately no one has (yet) opened a pull request to add new architectures / hardware to the lv_micropython repo.
Thank you very much for your help.
I have some basic understanding of C, but more on an Arduino level.
How to build C with GNU make I have no experience.
I fully understand the porting issue, if you can help me to port it to STM32 it would be great.
You are saying the lvgl is a “native” python module, so I guess I need to merge it with micropython and then upload the whole thing to the target board?
If so, how is it done? I really would need a step by step instruction.
So far I do the following to upload Micropython to he STM32 board:
I convert the .dfu file into a .hex file with the DFU file manager software
I upload the generated .hex file to the target hardware with the STM32 ST-Link Utility software.
At which point do I need to do what?
I am not sure if I have enough skills to do it by myself. So if it would be an option I would also pay someone to do it for me, including the STM32 porting, maybe you have an idea who could help me?
Or maybe it is less complicated than I think and you can walk me through the process?
Not exactly. You need to build Micropython with lvgl binding. The simplest way is to build lv_micopython. There is some work there to port it to STM32 and to port it to ILI9341 hardware.
No, you can’t download a compiled Micropython image. You need to build the image from sources.
I don’t know personally anyone who is ready to do it for money, but I’m sure you’ll find someone because it’s not a difficult task.
There are outsourcing websites you can try, just google it. (Personally I never tried using any outsourcing service so I cannot recommend a specific website or company)
