Hello everybody
Need your help again! My file manager is ready, but I would like to have a button navigation in the file list. The buttons are declared in the hardware libs and work when I press something. I can scroll the list but not the buttons in the list. As described here. https://forum.lvgl.io/t/list-manual-navigation-problems/3958/3
I then made a group for the list: The list is focused and the first button, but no navigation. I’ve tested various commands like in the code here. I would like to control the list buttons with up / down. Hope the code is enough to understand.
Screenshot with focus and without focus (adding a group does that), scrolling also works without a group. Need a tip or example… LVGL 5.3
Thank you very much!
static lv_obj_t* list;//Dateiliste global
//From HW Libs, changed see at end of the funktion
static bool _jc_virt_mouse_read(lv_indev_data_t* data)
// Poll Joy-Con.
jc_gamepad_rpt_t* jc_pad = joycon_poll();
if (!jc_pad)
return false;
// Take a screenshot if Capture button is pressed.
if (jc_pad->cap)
_save_fb_to_bmp();
msleep(1000);
// Calibrate left stick.
if (!jc_drv_ctx.centering_done)
if (jc_pad->conn_l
&& jc_pad->lstick_x > 0x400 && jc_pad->lstick_y > 0x400
&& jc_pad->lstick_x < 0xC00 && jc_pad->lstick_y < 0xC00)
jc_drv_ctx.cx_max = jc_pad->lstick_x + 0x72;
jc_drv_ctx.cx_min = jc_pad->lstick_x - 0x72;
jc_drv_ctx.cy_max = jc_pad->lstick_y + 0x72;
jc_drv_ctx.cy_min = jc_pad->lstick_y - 0x72;
jc_drv_ctx.centering_done = true;
jc_drv_ctx.cursor_timeout = 0;
return false;
// Re-calibrate on disconnection.
if (!jc_pad->conn_l)
jc_drv_ctx.centering_done = 0;
// Set button presses. //Buttons Joycon Funktion gedrückt
if (jc_pad->a || jc_pad->zl || jc_pad->zr)
// Enable console. //Buttons Joycon Debug Konsole aktivieren
if (jc_pad->plus || jc_pad->minus)
if (((u32)get_tmr_ms() - jc_drv_ctx.console_timeout) > 1000)
if (!console_enabled)
display_activate_console();
console_enabled = true;
gfx_con_getpos(&gfx_con.savedx, &gfx_con.savedy);
gfx_con_setpos(964, 630);
gfx_printf("Press -/+ to close");
gfx_con_setpos(gfx_con.savedx, gfx_con.savedy);
display_deactivate_console();
console_enabled = false;
jc_drv_ctx.console_timeout = get_tmr_ms();
return false;
if (console_enabled)
gfx_con_setpos(32, 630);
gfx_con.fntsz = 8;
gfx_printf("x: %4X, y: %4X | b: %06X | bt: %d %0d | cx: %03X - %03x, cy: %03X - %03x",
jc_pad->lstick_x, jc_pad->lstick_y, jc_pad->buttons,
jc_pad->batt_info_l, jc_pad->batt_info_r,
jc_drv_ctx.cx_min, jc_drv_ctx.cx_max, jc_drv_ctx.cy_min, jc_drv_ctx.cy_max);
gfx_con.fntsz = 16;
return false;
// Calculate new cursor position.
if (jc_pad->lstick_x <= jc_drv_ctx.cx_max && jc_pad->lstick_x >= jc_drv_ctx.cx_min)
jc_drv_ctx.pos_x += 0;
else if (jc_pad->lstick_x > jc_drv_ctx.cx_max)
jc_drv_ctx.pos_x += ((jc_pad->lstick_x - jc_drv_ctx.cx_max) / 30);
jc_drv_ctx.pos_x -= ((jc_drv_ctx.cx_min - jc_pad->lstick_x) / 30);
if (jc_pad->lstick_y <= jc_drv_ctx.cy_max && jc_pad->lstick_y >= jc_drv_ctx.cy_min)
jc_drv_ctx.pos_y += 0;
else if (jc_pad->lstick_y > jc_drv_ctx.cy_max)
jc_drv_ctx.pos_y -= ((jc_pad->lstick_y - jc_drv_ctx.cy_max) / 30);
jc_drv_ctx.pos_y += ((jc_drv_ctx.cy_min - jc_pad->lstick_y) / 30);
// Ensure value inside screen limits.
if (jc_drv_ctx.pos_x < 0)
jc_drv_ctx.pos_x = 0;
else if (jc_drv_ctx.pos_x > 1279)
jc_drv_ctx.pos_x = 1279;
if (jc_drv_ctx.pos_y < 0)
jc_drv_ctx.pos_y = 0;
else if (jc_drv_ctx.pos_y > 719)
jc_drv_ctx.pos_y = 719;
// Set cursor position.
data->point.x = jc_drv_ctx.pos_x;
data->point.y = jc_drv_ctx.pos_y;
// Auto hide cursor.
if (jc_drv_ctx.pos_x != jc_drv_ctx.pos_last_x || jc_drv_ctx.pos_y != jc_drv_ctx.pos_last_y)
jc_drv_ctx.pos_last_x = jc_drv_ctx.pos_x;
jc_drv_ctx.pos_last_y = jc_drv_ctx.pos_y;
jc_drv_ctx.cursor_hidden = false;
jc_drv_ctx.cursor_timeout = get_tmr_ms();
lv_indev_set_cursor(jc_drv_ctx.indev, jc_drv_ctx.cursor);
// Un hide cursor.
lv_obj_set_opa_scale_enable(jc_drv_ctx.cursor, false);
if (!jc_drv_ctx.cursor_hidden)
if (((u32)get_tmr_ms() - jc_drv_ctx.cursor_timeout) > 3000)
// Remove cursor and hide it.
lv_indev_set_cursor(jc_drv_ctx.indev, NULL);
lv_obj_set_opa_scale_enable(jc_drv_ctx.cursor, true);
lv_obj_set_opa_scale(jc_drv_ctx.cursor, LV_OPA_TRANSP);
jc_drv_ctx.cursor_hidden = true;
data->state = LV_INDEV_STATE_REL; // Ensure that no clicks are allowed.
//Button Joycon Funktion schliessen geändert zu x
if (jc_pad->x && close_btn)
lv_action_t close_btn_action = lv_btn_get_action(close_btn, LV_BTN_ACTION_CLICK);
close_btn_action(close_btn);
close_btn = NULL;
//Button Joycon Funktion Folder Back b
if (jc_pad->b && btn_back)
lv_action_t back_btn_action = lv_btn_get_action(btn_back, LV_BTN_ACTION_CLICK);//reagiert extrem schnell geht manchmal mehrere Ordner zurück
//lv_action_t back_btn_action = lv_btn_get_action(btn_back, LV_BTN_ACTION_LONG_PR_REPEAT);//alles andere verursacht error
back_btn_action(btn_back);
//btn_back = NULL;
//Button Joycon Funktion hier freeze wenn im Hauptmenü, mit (&& list) ok
if (jc_pad->up && list)
lv_list_up(list);//Scrollen ok
if (jc_pad->down && list)
lv_list_down(list);//Scrollen ok
//lv_list_focus(btn, false);//Auf erster Listeninhalt fokusieren
//lv_list_get_next_btn(list, NULL);
//LV_GROUP_KEY_NEXT;
//lv_obj_t* focus = lv_list_get_next_btn(list, NULL);
//lv_list_focus(focus, true);//Auf erster Listeninhalt fokusieren
//LV_GROUP_KEY_DOWN
//LV_KEY_RIGHT / DOWN Select the next button
//LV_KEY_LEFT / UP Select the previous button
//lv_list_down(list);
return false; // No buffering so no more data read.
//File und Folder List Filemanager erstellen
void create_filemenu(const char* path, lv_obj_t* parent)
//You can navigate manually in the list with lv_list_up(list) and lv_list_down(list) .
//You can focus on a button directly using lv_list_focus(btn, anim_en) .
//The animation time of up / down / focus movements can be set via : lv_list_set_anim_time(list, anim_time).Zero animation time means not animations.
//I added lv_list_set_btn_selected(list, btn) and lv_list_get_btn_selected(list) function.
list = lv_list_create(win_fm, NULL);//only sample..........
//Benötigt USE_LV_GROUP 1, Wenn aktiviert ist die Liste eingerahmt und der erste Button angewählt
lv_group_t* listnav = lv_group_create();
lv_group_add_obj(listnav, list);
