List button event handler not getting called
I have a simple lv_list and I want to navigate through it using a keypad. To achieve this I am using lv_indev and lv_groups. Below is my code. The problem I am facing is, the list’s button handler function event_handler is not getting called when the LV_KEY_ENTER is being pressed. But the list can be scrolled up and down using up/down or left/right buttons of the keypad. I had this working on LVGL version 7 but after updating to 8 it stopped.
What am I doing wrong?
Thanks
STM32G4 on a custom board
Zephyr 3.2
LVGL v 8.2.0
I want use lv_list and lv_groups to make a multi level settings menu. I had it working on LVGL version 7
I enabled the LVGL logs to find out whether the key presses are getting detected or not. It looks to me they are getting detected fine, but the button event handler doesn’t get called.
static lv_group_t * m_group = NULL;
static lv_obj_t * list1 = NULL;
static lv_indev_drv_t m_keypad_drv;
static lv_indev_t * m_keypad_indev = NULL;
static void event_handler(lv_event_t *event)
    lv_obj_t * obj = lv_event_get_target(event);
    LOG_INF("code %d", code);
    	LOG_INF("Clicked: %s", lv_list_get_btn_text(list1, obj));
static void keypad_read(lv_indev_drv_t *drv, lv_indev_data_t *data) {
	static int call_count = 0;
	switch (m_key_pressed) {
	case CHECK:
		data->key = LV_KEY_ENTER;
		break;
	case BACK:
		data->key = LV_KEY_ESC;
		break;
	case LEFT:
		data->key = LV_KEY_LEFT;
		break;
	case RIGHT:
		data->key = LV_KEY_RIGHT;
		break;
	case UP:
		data->key = LV_KEY_UP;
		break;
	case DOWN:
		data->key = LV_KEY_DOWN;
		break;
	case POWER:
		break;
	case HOME:
		break;
	default:
		break;
	/* key press */
	if (m_key_pressed != NONE) {
		if (call_count == 0) {
			call_count = 1;
		} else if (call_count == 1) {
			call_count = 2;
	/* reset the keys */
	if ((m_key_pressed != NONE) && (call_count == 2)) {
		call_count = 0;
		m_key_pressed = NONE;
		m_press_type = UNKNOWN;
void keypad_app_cb_handler(...) {
    /* interrupt callback function to set m_key_pressed variable */
void lv_ex_list_1(void) {
    /*Create a list*/
    /*lv_obj_t * */list1 = lv_list_create(lv_scr_act());
    lv_obj_set_size(list1, 128, 64);
    lv_obj_align(list1, LV_ALIGN_CENTER, 0, 0);
    /*Add buttons to the list*/
    lv_obj_t * list_btn;
    list_btn = lv_list_add_btn(list1, LV_SYMBOL_FILE, "New");
    lv_obj_add_event_cb(list_btn, event_handler, LV_EVENT_CLICKED, NULL);
    list_btn = lv_list_add_btn(list1, LV_SYMBOL_DIRECTORY, "Open");
    list_btn = lv_list_add_btn(list1, LV_SYMBOL_CLOSE, "Delete");
    list_btn = lv_list_add_btn(list1, LV_SYMBOL_EDIT, "Edit");
    list_btn = lv_list_add_btn(list1, LV_SYMBOL_SAVE, "Save");
    list_btn = lv_list_add_btn(list1, LV_SYMBOL_BELL, "Notify");
    list_btn = lv_list_add_btn(list1, LV_SYMBOL_BATTERY_FULL, "Battery");
static int setup_keypad() {
	int ret = 0;
	lv_indev_drv_init(&m_keypad_drv);
	m_keypad_drv.type = LV_INDEV_TYPE_KEYPAD;
	m_keypad_drv.read_cb = keypad_read;
	m_keypad_indev = lv_indev_drv_register(&m_keypad_drv);
void main() {
        setup_keypad();
	g = lv_group_create();
	lv_indev_set_group(m_keypad_indev, g);
	lv_ex_list_1();
	lv_group_add_obj(g, list1);
        while (1)  {
            lv_task_handler();
            k_sleep(K_MSEC(10));
Logs
[Info]  (6.354, +5961)   indev_keypad_proc: 10 key is pressed   (in lv_indev.c line #413)
[Info]  (6.392, +38)     indev_keypad_proc: 10 key is released  (in lv_indev.c line #497)
[Info]  (94.786, +82788)         indev_keypad_proc: 19 key is pressed   (in lv_indev.c line #413)
[Info]  (94.819, +33)    indev_keypad_proc: 19 key is released  (in lv_indev.c line #497)
[Info]  (97.281, +2462)  indev_keypad_proc: 17 key is pressed   (in lv_indev.c line #413)
[Info]  (97.313, +32)    indev_keypad_proc: 17 key is released  (in lv_indev.c line #497)
Further debugging shows that event is being sent but the handler function does not get called. From the below logs I understand that the address where the event is being sent is of the lv_list and not the list button. Since the lv_list object doesn’t have a handler added, it does not get called.
Now my question is, why is the event getting triggered for the list object and not the list button?
[Info]  (30.020, +7786)  indev_keypad_proc: 10 key is pressed   (in lv_indev.c line #413)
[Trace] (30.028, +8)     event_send_core: Sending event 13 to 0x20002394 with 0x2000b87c param  (in lv_event.c line #428)
[Trace] (30.038, +10)    event_send_core: Sending event 44 to 0x20002394 with 0x2000b7d4 param  (in lv_event.c line #428)
[Trace] (30.049, +11)    event_send_core: Sending event 1 to 0x20002394 with 0x2000230c param   (in lv_event.c line #428)
[Info]  (30.070, +21)    indev_keypad_proc: 10 key is released  (in lv_indev.c line #497)
[Trace] (30.077, +7)     event_send_core: Sending event 8 to 0x20002394 with 0x2000230c param   (in lv_event.c line #428)
[Trace] (30.088, +11)    event_send_core: Sending event 4 to 0x20002394 with 0x2000230c param   (in lv_event.c line #428)
[Trace] (30.098, +10)    event_send_core: Sending event 7 to 0x20002394 with 0x2000230c param   (in lv_event.c line #428)
