I will be the first to admit, I really don’t know what I’m doing. I found a button demo for one of my cheap yellow display boards, and started following the LVGL docs for version 8.3.0. And figured out how to make a slider, get it close to where I wanted on the screen, make a second slider, make a checkbox, and place another button. All this is fine, and works.
However my next step is wanting the two sliders linked together (IE: These will be Left and Right motor controls for a robot) When linked they should have the same values and it should not matter which slider I use to set those values. I want to use the checkbox to unlink/relink them.
In otherwords, when unlinked I will use them to set each motor independent of each other.
Everything I’ve tried has caused the ESP32 to reset/reboot. I am clearly missing something.
I am just not sure what I’m missing, or how to do what I want. Thanks for any help/advice in advance.
Cheap Yellow Display ESP32 - Arduino IDE 1.8.19
8.3.0
Linking and unlinking two slider, so they work together or independent from each other.
I have a flag that is set ( bool slideLock = 1 ). Inside the slider_event_cb event I check the flag and like this:
currentLeft = lv_slider_get_value(slider);
if (slideLock == 1) { //check the checkbox
currentRight = currentLeft;
//lv_slider_set_value(slider2, currentRight, LV_ANIM_OFF);
//lv_obj_add_event_cb(slider2, slider2_event_cb, LV_EVENT_VALUE_CHANGED, NULL);
I tried to set both sides, but this causes a reboot. And as you can see is currently commented out.
I have only do this in one of the slider events so far because it keeps resetting. I didn’t want to duplicate the code just yet.
I also tried to disable/enable the RIGHT (slider2) in the event_handler for the checkbox
static void event_handler(lv_event_t * e)
if(code == LV_EVENT_VALUE_CHANGED) {
const char * txt = lv_checkbox_get_text(obj);
const char * state = lv_obj_get_state(obj) & LV_STATE_CHECKED ? "Checked" : "Unchecked";
LV_LOG_USER("%s: %s", txt, state);
Serial.printf("%s: %s\n", txt, state);
slideLock = !slideLock;
//if (slideLock == 1) {lv_obj_clear_flag(slider2, LV_OBJ_FLAG_CLICKABLE); } else { lv_obj_add_flag(slider2, LV_OBJ_FLAG_CLICKABLE); }
attempting to make the slider2 clickable and not clickable - this also caused the ESP32 to reset. And really isn’t what I wanted to do. But I thought I’d try it.
Complete code below. (It’s messy, and I’m sure has a lot of mistakes I made along the way.)
#include <lvgl.h>
#include <TFT_eSPI.h>
#include "CST820.h"
static const uint16_t screenWidth = 240;
static const uint16_t screenHeight = 320;
#define I2C_SDA 33
#define I2C_SCL 32
#define TP_RST 25
#define TP_INT 21
static lv_color_t *buf1;
static lv_color_t *buf2;
static lv_obj_t * slider_label;
static lv_obj_t * slider2_label;
static lv_obj_t * slider;
static lv_obj_t * slider2;
TFT_eSPI tft = TFT_eSPI(); /* TFT实例 */
CST820 touch(I2C_SDA, I2C_SCL, TP_RST, TP_INT); /* 触摸实例 */
//int prevBlueYSlider, prevRedYSlider; //Blue = Right and Red = Left
uint8_t currentLeft, currentRight;
bool slideLock = 1; //sliders locked together
//_______________________
void lv_example_btn(void)
/*要转换的属性*/
static lv_style_prop_t props[] = {
LV_STYLE_TRANSFORM_WIDTH, LV_STYLE_TRANSFORM_HEIGHT, LV_STYLE_TEXT_LETTER_SPACE};
/*Transition descriptor when going back to the default state.
*Add some delay to be sure the press transition is visible even if the press was very short*/
static lv_style_transition_dsc_t transition_dsc_def;
lv_style_transition_dsc_init(&transition_dsc_def, props, lv_anim_path_overshoot, 250, 100, NULL);
/*Transition descriptor when going to pressed state.
*No delay, go to presses state immediately*/
static lv_style_transition_dsc_t transition_dsc_pr;
lv_style_transition_dsc_init(&transition_dsc_pr, props, lv_anim_path_ease_in_out, 250, 0, NULL);
/*Add only the new transition to he default state*/
static lv_style_t style_def;
lv_style_init(&style_def);
lv_style_set_transition(&style_def, &transition_dsc_def);
/*Add the transition and some transformation to the presses state.*/
static lv_style_t style_pr;
lv_style_init(&style_pr);
lv_style_set_transform_width(&style_pr, 10);
lv_style_set_transform_height(&style_pr, -10);
lv_style_set_text_letter_space(&style_pr, 10);
lv_style_set_transition(&style_pr, &transition_dsc_pr);
lv_obj_t *btn1 = lv_btn_create(lv_scr_act());
//lv_obj_align(btn1, LV_ALIGN_CENTER, 0, -80);
lv_obj_align(btn1, LV_ALIGN_OUT_RIGHT_MID, 95, 85);
lv_obj_add_style(btn1, &style_pr, LV_STATE_PRESSED);
lv_obj_add_event_cb(btn1, btn1_event_handler, LV_EVENT_ALL, NULL);
lv_obj_add_style(btn1, &style_def, 0);
lv_obj_t *label = lv_label_create(btn1);
lv_label_set_text(label, "GO!");
/*Init the style for the default state*/
static lv_style_t style;
lv_style_init(&style);
lv_style_set_radius(&style, 3);
lv_style_set_bg_opa(&style, LV_OPA_100);
lv_style_set_bg_color(&style, lv_palette_main(LV_PALETTE_BLUE));
lv_style_set_bg_grad_color(&style, lv_palette_darken(LV_PALETTE_BLUE, 2));
lv_style_set_bg_grad_dir(&style, LV_GRAD_DIR_VER);
lv_style_set_border_opa(&style, LV_OPA_40);
lv_style_set_border_width(&style, 2);
lv_style_set_border_color(&style, lv_palette_main(LV_PALETTE_GREY));
lv_style_set_shadow_width(&style, 8);
lv_style_set_shadow_color(&style, lv_palette_main(LV_PALETTE_GREY));
lv_style_set_shadow_ofs_y(&style, 8);
lv_style_set_outline_opa(&style, LV_OPA_COVER);
lv_style_set_outline_color(&style, lv_palette_main(LV_PALETTE_BLUE));
lv_style_set_text_color(&style, lv_color_white());
lv_style_set_pad_all(&style, 10);
/*Init the pressed style*/
static lv_style_t style_pr_2;
lv_style_init(&style_pr_2);
/*Ad a large outline when pressed*/
lv_style_set_outline_width(&style_pr_2, 30);
lv_style_set_outline_opa(&style_pr_2, LV_OPA_TRANSP);
lv_style_set_translate_y(&style_pr_2, 5);
lv_style_set_shadow_ofs_y(&style_pr_2, 3);
lv_style_set_bg_color(&style_pr_2, lv_palette_darken(LV_PALETTE_BLUE, 2));
lv_style_set_bg_grad_color(&style_pr_2, lv_palette_darken(LV_PALETTE_BLUE, 4));
/*Add a transition to the the outline*/
static lv_style_transition_dsc_t trans;
static lv_style_prop_t props2[] = {LV_STYLE_OUTLINE_WIDTH, LV_STYLE_OUTLINE_OPA};
lv_style_transition_dsc_init(&trans, props2, lv_anim_path_linear, 300, 0, NULL);
lv_style_set_transition(&style_pr_2, &trans);
lv_obj_t *btn2 = lv_btn_create(lv_scr_act());
lv_obj_remove_style_all(btn2); /*Remove the style coming from the theme*/
lv_obj_add_style(btn2, &style, 0);
lv_obj_add_event_cb(btn2, btn2_event_handler, LV_EVENT_ALL, NULL);
lv_obj_add_style(btn2, &style_pr_2, LV_STATE_PRESSED);
lv_obj_set_size(btn2, LV_SIZE_CONTENT, LV_SIZE_CONTENT);
lv_obj_center(btn2);
lv_obj_t *label2 = lv_label_create(btn2);
lv_label_set_text(label2, "Reverse");
lv_obj_center(label2);
/*Create a slider in the center of the display*/
lv_obj_t * slider = lv_slider_create(lv_scr_act());
//lv_obj_center(slider);
lv_obj_add_event_cb(slider, slider_event_cb, LV_EVENT_VALUE_CHANGED, NULL);
lv_obj_set_size(slider, 20, 155);
lv_obj_align(slider, LV_ALIGN_OUT_LEFT_BOTTOM, 10, 100);
/*Create a label below the slider*/
slider_label = lv_label_create(lv_scr_act());
lv_label_set_text(slider_label, "50");
lv_obj_align_to(slider_label, slider, LV_ALIGN_OUT_BOTTOM_MID, 0, 10);
lv_slider_set_range(slider, 50, 128);
lv_obj_t * slider2 = lv_slider_create(lv_scr_act());
// lv_obj_center(slider2);
lv_obj_set_size(slider2, 20, 155);
lv_obj_align(slider2, LV_ALIGN_OUT_LEFT_BOTTOM, 45, 100);
slider2_label = lv_label_create(lv_scr_act());
lv_label_set_text(slider2_label, "50");
lv_obj_align_to(slider2_label, slider2, LV_ALIGN_OUT_BOTTOM_MID, 0, 10);
lv_slider_set_range(slider2, 50, 128);
// lv_slider_set_value(slider2, 128, LV_ANIM_OFF);
// lv_event_send(slider2, LV_EVENT_VALUE_CHANGED, NULL);
//lv_obj_clear_flag(slider2, LV_OBJ_FLAG_CLICKABLE); //, true); //false);
//lv_obj_set_hidden(slider2, true);
//Checkbox
lv_obj_t * cb;
cb = lv_checkbox_create(lv_scr_act());
lv_checkbox_set_text(cb, "Lock");
lv_obj_add_state(cb, LV_STATE_CHECKED);
lv_obj_add_event_cb(cb, event_handler, LV_EVENT_ALL, NULL);
lv_obj_align(cb, LV_ALIGN_OUT_LEFT_TOP, 30, 60);
lv_obj_update_layout(cb);
static void slider_event_cb(lv_event_t * e)
// This is the Left Slider (RED)
lv_obj_t * slider = lv_event_get_target(e);
char buf[8];
lv_snprintf(buf, sizeof(buf), "%d%", lv_slider_get_value(slider));
lv_label_set_text(slider_label, buf);
Serial.print("Slider Left : "); Serial.println(currentLeft);
Serial.print("Slider Right: "); Serial.println(currentRight);
static void slider2_event_cb(lv_event_t * e)
lv_obj_t * slider2 = lv_event_get_target(e);
char buf[8];
lv_snprintf(buf, sizeof(buf), "%d%", lv_slider_get_value(slider2));
lv_label_set_text(slider2_label, buf);
Serial.print("Slider 2: ");Serial.println(buf);
Serial.print("Slider Left: "); Serial.println(currentLeft);
static void btn1_event_handler(lv_event_t * e)
if (code == LV_EVENT_PRESSING) {
Serial.println("Green On!");
digitalWrite(16, LOW); //!digitalRead(4));
else if (code == LV_EVENT_RELEASED) {
Serial.println("Green Off!");
digitalWrite(16, HIGH);
static void btn2_event_handler(lv_event_t * e)
LV_LOG_USER("Clicked");
digitalWrite(4, !digitalRead(4));
else if(code == LV_EVENT_VALUE_CHANGED) {
LV_LOG_USER("Toggled");
//tft.startWrite();
tft.pushImage(area->x1, area->y1, w, h, (uint16_t *)color_p);
//tft.endWrite();
lv_disp_flush_ready(disp);
void my_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data)
bool touched;
uint8_t gesture;
uint16_t touchX, touchY;
touched = touch.getTouch(&touchX, &touchY, &gesture);
if (!touched)
//Set the coordinates
data->point.x = touchX;
data->point.y = touchY;
void setup()
pinMode(4, OUTPUT);
pinMode(16, OUTPUT);
pinMode(17, OUTPUT);
digitalWrite(4, HIGH);
digitalWrite(17, HIGH);
Serial.begin(115200); /*初始化串口*/
LVGL_Arduino += String('V') + lv_version_major() + "." + lv_version_minor() + "." + lv_version_patch();
Serial.println(LVGL_Arduino);
Serial.println("I am LVGL_Arduino");
pinMode(27, OUTPUT);
digitalWrite(27, LOW);
tft.begin(); /*初始化*/
tft.setRotation(0); /* 旋转 */
tft.init(); /* 初始化DMA */
touch.begin(); /*初始化触摸板*/
digitalWrite(27, HIGH);
buf1 = (lv_color_t *)heap_caps_malloc(sizeof(lv_color_t) * screenWidth * 200 , MALLOC_CAP_DMA | MALLOC_CAP_INTERNAL);//screenWidth * screenHeight/2
buf2 = (lv_color_t *)heap_caps_malloc(sizeof(lv_color_t) * screenWidth * 200 , MALLOC_CAP_DMA | MALLOC_CAP_INTERNAL);
lv_disp_draw_buf_init(&draw_buf, buf1, buf2, screenWidth * 200);
lv_disp_drv_init(&disp_drv);
lv_example_btn();
Serial.println("Setup done");
tft.startWrite();
currentRight = 50; //copied from previous Joystick 03 example
currentLeft = 50;
void loop()
lv_timer_handler(); /* 让GUI完成它的工作 */
delay(5);
The picture is pretty bad, but here it is.
