I am beginning using the:
ESP32-S3-Touch-LCD-7
Waveshare display 7" with
ESP32-S3 using LVGL libraries with touch.
I followed the examples on the Instructions_wiki.pdf and, correcting some
errors, I was able to run them, except the lvgl_porting.
The example compiles, but at the linking phase it gives this error
Linking .pio\build\default\firmware.elf
C:/Users/JDS/.platformio/packages/toolchain-xtensa-esp-elf/bin/…/lib/gcc/xtensa-esp-elf/13.2.0/…/…/…/…/xtensa-esp-elf/bin/ld.exe: .pio\build\default\lvgl_Porting\main\rgb_lcd_example_main.c.o:(.literal.example_lvgl_touch_cb+0x0): undefined reference to `esp_lcd_touch_read_data’
and more errors all of this type.
The function `esp_lcd_touch_read_data’ exists, is declared and defined and reachable.
In between, I found that the function has a differente declaration/definition signature, that its use:
esp_lcd_touch_read_data(drv->user_data);
esp_err_t esp_lcd_touch_read_data(esp_lcd_touch_handle_t tp);
So, the error!
I tried to find the same function, with the correct signature in the libraries I have, without success.
So, I declared/defined a function with the correct signature, trying to go on, but without success: same error.
I am using PlatformIo.
packages used:
PACKAGES:
- framework-espidf @ 3.50202.0 (5.2.2)
- tool-cmake @ 3.16.4
- tool-esptoolpy @ 1.40501.0 (4.5.1)
- tool-idf @ 1.0.1
- tool-mconf @ 1.4060000.20190628 (406.0.0)
- tool-ninja @ 1.9.0
- tool-riscv32-esp-elf-gdb @ 11.2.0+20220823
- tool-xtensa-esp-elf-gdb @ 11.2.0+20230208
- toolchain-esp32ulp @ 1.23500.220830 (2.35.0)
- toolchain-riscv32-esp @ 13.2.0+20230928
- toolchain-xtensa-esp-elf @ 13.2.0+20230928
and lvgl libraries on the WAVESHARE examples
S3-7-libraries
Any idea for help?
Thanks in advance
Joaquim Silva
