Lilygo T-Display S3
I have a LILYGO T-Display-S3 board with a 1.9" LCD & ST7789 controller, it has an 8 bit parallel interface.
I have tried with ESP-IDF 5.0 & 4.4.3 and LVGL 8.0.2
I’m using this example as a start point
https://github.com/UsefulElectronics/esp32s3_lilygo_8bit_parallel_display_lvgl
While the code compiles (needs a few fixes for minor compilation bugs) and runs it results in a black screen.
When I compare it to this Arduino code (which does work) I can see very little difference
https://github.com/Xinyuan-LilyGO/T-Display-S3/tree/main/example/lv_demos
The only thing that sticks out are some additional initialization instructions sent to the display (labelled CMD_1) but porting that change does not solve the problem.
One additional point is that if I run the UE code first, get a black screen, and then run the Arduino lv_demo code I very briefly at reset see the UE code’s output before it is replaced with the Arduino demo code output. This makes me think that it almost works but that I am missing some vital step
Has anybody had any success with the UE code?
Apparently I wan’t cleaning the build properly after trying with 5.0. Use 4.4.3 and it works
such id the problems with ESP32 so many problems between versions
Can confirm changing the esp-idf version to v4.4.3 worked. Tried with v5.0 but didn’t work
Any updates on this issue?
What’s your question? Are you asking about the esp-idf? I’m still using 4.4 (successfully). I’m using VS Code + PIOArduino.
-Jeff
