My lcd have a gap in the bottom of the screen like in the picture.
My code is :
void tft_init(void)
static lv_color_t disp_buf1[TFT_HOR_RES * 30];
static lv_disp_buf_t buf;
lv_disp_buf_init(&buf, disp_buf1, NULL, TFT_HOR_RES * 30);
lv_disp_drv_init(&disp_drv);
#if TFT_EXT_FB != 0
SDRAM_Init();
LCD_Config();
DMA_Config();
disp_drv.buffer = &buf;
disp_drv.flush_cb = tft_flush;
#if TFT_USE_GPU != 0
DMA2D_Config();
disp_drv.gpu_blend_cb = gpu_mem_blend;
disp_drv.gpu_fill_cb = gpu_mem_fill;
static void tft_flush(lv_disp_drv_t * drv, const lv_area_t * area, lv_color_t * color_p)
/Return if the area is out the screen/
if(area->x2 < 0) return;
if(area->y2 < 0) return;
if(area->x1 > TFT_HOR_RES - 1) return;
if(area->y1 > TFT_VER_RES - 1) return;
int32_t act_x2 = area->x2 > TFT_HOR_RES - 1 ? TFT_HOR_RES - 1 : area->x2;
int32_t act_y2 = area->y2 > TFT_VER_RES - 1 ? TFT_VER_RES - 1 : area->y2;
x1_flush = act_x1;
y1_flush = act_y1;
x2_flush = act_x2;
y2_fill = act_y2;
y_fill_act = act_y1;
buf_to_flush = color_p;
/*##-7- Start the DMA transfer using the interrupt mode #*/
/* Configure the source, destination and buffer size DMA fields and Start DMA Stream transfer */
/* Enable All the DMA interrupts */
HAL_StatusTypeDef err;
err = HAL_DMA_Start_IT(&DmaHandle,(uint32_t)buf_to_flush, (uint32_t)&my_fb[y_fill_act * TFT_HOR_RES + x1_flush],
(x2_flush - x1_flush + 1));
if(err != HAL_OK)
while(1); /*Halt on error*/
is there anything wrong? or any advise please, help me. thank you
