I have noticed that the last major tickline isn’t drawn on any of the axis’. Is this a bug?
Simulator
The newest. Just downloaded it to make sure it wasn’t already fixed
I would like to have the last tick lines drawn on my axis’
I have messed a bit around in lv_chart.c
but it hasnt changed anything.
I don’t think its a problem with my code but… you never know of course.
I hope I included all the necessary parts. This is quickly put together from the “actual code”
char yValueList[100] = {""};
char xValueList[100] = {""};
char yValue[10] = {""};
char xValue[10] = {""};
lv_chart_ext_t * chart_ext;
lv_chart_axis_cfg_t * x_axis_ext;
lv_chart_axis_cfg_t * y_axis_ext;
static lv_obj_t* chart = NULL;
void func(void) {
chart = lv_chart_create(lv_scr_act(), NULL);
//lv_obj_add_style (chart, LV_CHART_PART_BG, &style_win_bg);
lv_obj_set_style_local_size (chart, LV_CHART_PART_SERIES, LV_STATE_DEFAULT, 1);
lv_obj_set_style_local_line_width (chart, LV_CHART_PART_SERIES, LV_STATE_DEFAULT, 0);
lv_obj_set_size (chart, 220, 240);
lv_obj_align (chart, Container, LV_ALIGN_CENTER, 0, 0);
lv_chart_set_type (chart, LV_CHART_TYPE_LINE); //Show lines and points too
lv_chart_set_update_mode (chart, LV_CHART_UPDATE_MODE_SHIFT);
lv_chart_set_point_count (chart, POINTCOUNT);
lv_chart_set_range (chart, -30, 40);
lv_obj_set_event_cb (chart, Scrollable_cb);
//lv_chart_cursor_t *c1 = lv_chart_add_cursor(chart, LV_COLOR_RED, LV_CHART_CURSOR_LEFT);
lv_obj_set_style_local_pad_top (chart, LV_OBJ_PART_MAIN, LV_STATE_DEFAULT, 10);
lv_obj_set_style_local_pad_bottom (chart, LV_OBJ_PART_MAIN, LV_STATE_DEFAULT, 30);
lv_obj_set_style_local_pad_left (chart, LV_OBJ_PART_MAIN, LV_STATE_DEFAULT, 50);
lv_obj_set_style_local_pad_right (chart, LV_OBJ_PART_MAIN, LV_STATE_DEFAULT, 25);
lv_obj_set_style_local_text_font (chart, LV_OBJ_PART_MAIN, LV_STATE_DEFAULT, &lv_font_unscii_8);
AxisPlotter(chart, XminData /*this is just integers*/, XmaxData /*this is just integers*/![image|237x317], 3, 4, chart_ext->ymax[LV_CHART_AXIS_PRIMARY_Y], chart_ext->ymin[LV_CHART_AXIS_PRIMARY_Y], (int) (chart_ext->ymax[LV_CHART_AXIS_PRIMARY_Y]-chart_ext->ymin[LV_CHART_AXIS_PRIMARY_Y])/10, 3, 3, 2);
void AxisPlotter(lv_obj_t * chart, int xMin, int xMax, int xTickLength, int xMinorLine, int yMin, int yMax, int yTickLength, int yMinorLine, int hDiv, int vDiv) {
if (chart == NULL) return;
y_axis_ext = &chart_ext->y_axis;
x_axis_ext = &chart_ext->x_axis;
y_axis_ext->options = LV_CHART_AXIS_DRAW_LAST_TICK;
x_axis_ext->options = LV_CHART_AXIS_INVERSE_LABELS_ORDER;
lv_chart_refresh(chart);
strcpy(yValueList,"");
strcpy(xValueList,"");
strcpy(yValue,"");
strcpy(xValue,"");
for (int y = 0; y <= yTickLength; y++) {
sprintf(yValue, "%i", (int)(((yMax - yMin) * y / yTickLength) + yMin));
strcat(yValueList, yValue);
if (y < yTickLength) {
strcat(yValueList, "\n");
for (int x = 0; x <= xTickLength; x++) {
sprintf(xValue, "%i", (int)(((xMax - xMin) * x / xTickLength) + xMin));
strcat(xValueList, xValue);
if (x < xTickLength) {
strcat(xValueList, "\n");
//strcat(xValueList, "0");
//strcat(yValueList, "0");
lv_chart_set_y_tick_length(chart, 4, 3);
lv_chart_set_y_tick_texts(chart, yValueList, yMinorLine, NULL);
lv_chart_set_div_line_count(chart,hDiv,vDiv);
lv_chart_set_x_tick_texts(chart, xValueList, xMinorLine, NULL);
lv_chart_set_x_tick_length(chart, 4, 3);
As visible on the end of the X-axis there is missing a tick mark, and likewise at the start of the y axis
Is this intentional or is it my mistake and is there any fix?
