Label Set Functions like lv_label_set_text and lv_label_set_text_fmt is not working properly always.
ESP32 Based Custom Board
8.3.11
I am reading temperature and humidity data from a sensor, which I want to update on the display
I tried to understand if this is the problem with the variables holding temperature and humidity values or something else. My variables contain correct data, the lvgl functions are not able to update the data.
void app_main(void)
dht11_init(DHT11_PIN);
display_init();
ui_init();
current_language = LANGUAGE_ENGLISH;
update_labels(current_language);
while (true)
vTaskDelay(MAIN_TASK_PERIOD / portTICK_PERIOD_MS);
// Get DHT11 Temperature and Humidity Values
if( dht11_read().status == DHT11_OK )
temperature = (uint8_t)dht11_read().temperature;
humidity = (uint8_t)dht11_read().humidity;
ESP_LOGI(TAG, "Temperature: %d", temperature);
ESP_LOGI(TAG, "Humidity: %d", humidity);
update_temperature_humidity();
ESP_LOGI(TAG, "Unable to Read DHT11 Status");
I can’t share the whole code it will be too big, but sharing some snippets to get some idea.
update_temperature_humidity function is called, and temperature and humidity are global variables.
The following is the update_temperature_humidity function.
static void update_temperature_humidity( void )
char buffer[10] = { 0 };
snprintf(buffer, 10, "%u °C", temperature);
lv_label_set_text(ui_lblTemperatureValue, buffer);
snprintf(buffer, 10, "%u °C", humidity);
lv_label_set_text(ui_lblHumidityValue, buffer);
// lv_label_set_text_fmt(ui_lblTemperatureValue, "%u °C", temperature);
// lv_label_set_text_fmt(ui_lblHumidityValue, "%u %%", humidity);
ESP_LOGI(TAG, "Temperature = %u and Humidity = %u Updated on Display", temperature, humidity);
I tried with both functions 'lv_label_set_textandlv_label_set_text_fmt`, I only see that sometimes the values are updated and not always.
I don’t have the screenshot, but can share the logs which show that values are not corrupted.
I (399) spi_flash: flash io: dio
I (404) app_start: Starting scheduler on CPU0
I (408) app_start: Starting scheduler on CPU1
I (408) main_task: Started on CPU0
I (418) main_task: Calling app_main()
I (1418) gpio: GPIO[0]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
Flushing Time: 50 ms
Flushing Time: 82 ms
I (7188) gpio: GPIO[12]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (7218) APP: Temperature: 22
I (7218) APP: Humidity: 69
I (7218) APP: Temperature = 22 and Humidity = 69 Updated on Display
I (12228) gpio: GPIO[12]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (12258) APP: Temperature: 22
I (12258) APP: Humidity: 67
I (12268) APP: Temperature = 22 and Humidity = 67 Updated on Display
I (17268) gpio: GPIO[12]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (17298) APP: Temperature: 22
I (17298) APP: Humidity: 67
I (17308) APP: Temperature = 22 and Humidity = 67 Updated on Display
I (22318) gpio: GPIO[12]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (22348) APP: Temperature: 22
I (22348) APP: Humidity: 67
I (22358) APP: Temperature = 22 and Humidity = 67 Updated on Display
As you see on logs value is correct but on display, there is no update (98% no update, sometimes in between the values are updated).
There is no crash the other widgets on the display just work fine.
Please suggest.
