Label and multi ttf fonts
Hello I am using LVGL 7.11 under linux with the FrameBuffer the UI is done with the NXP tools
GUI Guider
I have a Label text use to display track title from streaming service, and the text could be from anything
Latin, Korean etc a mix of several
I am using the Freetype Module to use a ttf Font. Is working for Latin1 text font.
But I didn’t know how I can mix several ttf into the same label (one for latin 1 (Roboto in my case) and another for Korean of Chinese or japonese Font.
Did some one has already trying this ?
Best Regards
JB
You probably have to cascade the fallback font, that way, if the glyph is not found in the main font, the fallback font will be checked recursively
korean_font->fallback = chinese_font;
latin_font->fallback = korean_font;
Then use the latin_font as the main font
