Works when using lv_btnmatrix but not lv_keyboard.
Looking to capture the “Enter” key.
for lv_btnmatrix…
def kb_cb(obj, event):
if event == lv.EVENT.CLICKED:
txt = obj.get_active_btn_text()
print("%s was pressed"%txt)
for lv_btnmatrix…
This should do the trick:
# Create a button with a label
txt = lv.btnmatrix.__cast__(obj).get_active_btn_text()
kb = lv.keyboard(scr)
kb.set_event_cb(kb_cb)
Thank you…
Would never of figure that it out in a million years!
In the future this would be solved without casting (on v8):
Now using v8.1…
trying …
obj = event.get_target()
txt = lv.btnmatrix.get_active_btn_text(obj)
get…
AttributeError: type object ‘btnmatrix’ has no attribute ‘get_active_btn_text’
changed…
txt = lv.btnmatrix.get_btn_text(obj)
now get…
TypeError: argument has wrong type
help please !
scr = lv.scr_act()
def kb_cb(event):
if event.get_code() == lv.EVENT.PRESSED: # v8 needs PRESSED not CLICKED
btnm = lv.btnmatrix.__cast__(event.get_target())
btn = btnm.get_selected_btn()
txt = btnm.get_btn_text(btn)
kb.add_event_cb(kb_cb, lv.EVENT.ALL, None)
Strangely this didn’t seem to work on the simulator… I still had to cast it manually to a btnmatrix, otherwise I got attribute errors.
One would think there would be a much simpler
way to get a keyboard key pressed.
I’ll give this a try…
Thank you again embeddedt
WORKS !!!
The weird casting is required because in this case get_target() returns an object of type lv_keyboard, and not lv_btnmatrix.
Although lv_keyboard inherits from lv_btnmatrix, it was decided that every child class should reimplement all its parent methods (except from lv_obj methods)
So, I would say this is a bug in LVGL API where lv_btnmatrix methods are not reimplemented in lv_keyboard.
@embeddedt / @kisvegabor - Do you agree?
Yes, I agree. The keyboard should have API function to get the pressed buttons.
I think we can simply add wrappers to lv_btnmatrix_get_selected_btn and lv_btnmatrix_get_btn_text.
Fixed on latest version.
Online example
in wrong post
