DID NOT find the issue…
Running code below, I wait ~ 2min and change map ABC or 1#
Get…
Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x40147810 PS : 0x00060030 A0 : 0x80147d9d A1 : 0x3ffd2e30
A2 : 0x3f821140 A3 : 0x3f821600 A4 : 0x00000000 A5 : 0x00000000
A6 : 0x3f46b149 A7 : 0x3f821600 A8 : 0x00000000 A9 : 0x00000000
A10 : 0x00001f01 A11 : 0x00000000 A12 : 0x00000001 A13 : 0x00000000
A14 : 0xffffffff A15 : 0x0000000c SAR : 0x0000001f EXCCAUSE: 0x0000001c
EXCVADDR: 0x00001f01 LBEG : 0x40096f2d LEND : 0x40096f51 LCOUNT : 0x8014a4cb
0x4014780d: allocate_btn_areas_and_controls at lv_btnmatrix.c:860
(inlined by) lv_btnmatrix_set_map at lv_btnmatrix.c:101
0x40147d9a: lv_btnmatrix_set_map at lv_btnmatrix.c:96
0x4014a4b5: lv_keyboard_def_event_cb at lv_keyboard.c:346
0x402397ed: lv_event_send at lv_event.c:76
0x4012bc26: event_send_core at lv_obj_event.c:310
0x4012bce2: lv_obj_send_event at lv_obj_event.c:64
0x401480b1: lv_btnmatrix_event at lv_btnmatrix.c:482
0x402386a5: lv_obj_event_base at lv_obj_event.c:87
0x4012bc15: event_send_core at lv_obj_event.c:307
0x40128dbd: indev_proc_press at lv_indev.c:1072
0x40128fbe: indev_pointer_proc at lv_indev.c:556
(inlined by) lv_indev_read_timer_cb at lv_indev.c:206
(inlined by) lv_indev_read_timer_cb at lv_indev.c:166
0x40144334: lv_timer_exec at lv_timer.c:346
(inlined by) lv_timer_handler at lv_timer.c:114
(inlined by) lv_timer_handler at lv_timer.c:71
0x400fd2b7: lv_task_handler at lv_api_map.h:42
0x400fbab3: mp_lv_task_handler at lv_mp.c:26471
0x40107935: lv_fun_builtin_var_call at lv_mp.c:103
0x400e4c6a: mp_call_function_n_kw at runtime.c:695
0x400e4dba: mp_call_method_n_kw at runtime.c:711
0x40086621: mp_execute_bytecode at vm.c:1042
0x400de704: fun_bc_call at objfun.c:278
0x401223be: mp_call_method_self_n_kw at objboundmeth.c:70
0x401223f1: bound_meth_call at objboundmeth.c:83
0x400e4d73: mp_call_function_1 at runtime.c:673
0x400e579e: mp_call_function_1_protected at runtime_utils.c:33
0x400e5928: mp_sched_run_pending at scheduler.c:110
(inlined by) mp_handle_pending at scheduler.c:239
0x400d8aa5: mp_hal_stdin_rx_chr at mphalport.c:103
0x400f0e2d: readline at readline.c:560
0x400f157e: pyexec_friendly_repl at pyexec.c:610
0x400d8844: mp_task at main.c:181
code used…
LC_MAP = ["1", "2", "3", "4", "5", "6", "7", "8", "9", "0", "\n",
"q", "w", "e", "r", "t", "y", "u", "i", "o", "p", "\n",
"a", "s", "d", "f", "g", "h", "j", "k", "l", "\n",
"ABC", "z", "x", "c", "v", "b", "n", "m", lv.SYMBOL.BACKSPACE, "\n",
"1#", lv.SYMBOL.LEFT, " ", lv.SYMBOL.RIGHT, lv.SYMBOL.NEW_LINE, None]
UC_MAP = ["!", "@", "#", "$", "%", "^", "&", "*", "(", ")", "\n",
"Q", "W", "E", "R", "T", "Y", "U", "I", "O", "P", "\n",
"A", "S", "D", "F", "G", "H", "J", "K", "L", "\n",
"abc", "Z", "X", "C", "V", "B", "N", "M", lv.SYMBOL.BACKSPACE, "\n",
SP_MAP = ["{", "}", "[", "]", "<", ">", "|" , "\\", "\n",
"~", "_", ":", ";", "\"", "'", ",", ".", "\n",
"abc", "/", "*", "-", "+", "=", "?", lv.SYMBOL.BACKSPACE,"\n",
" ", lv.SYMBOL.LEFT, " ", lv.SYMBOL.RIGHT, lv.SYMBOL.NEW_LINE, None]
CTRL_LC = [4, 4, 4, 4, 4, 4, 4, 4, 4, 4,
6, 4, 4, 4, 4, 4, 4, 4, 4,
4, 4, 10, 4, 4,]
CTRL_UC = [4, 4, 4, 4, 4, 4, 4, 4, 4, 4,
4, 4, 10, 4, 4,]
CTRL_SP = [4, 4, 4, 4, 4, 4, 4, 4,
5, 4, 4, 4, 4, 4, 4, 4,
lv.btnmatrix.CTRL.HIDDEN | 4, 4, 10, 4, 4,]
def kb_cb(event):
code = event.get_code()
obj = event.get_target_obj()
if code == lv.EVENT.PRESSED:
id = obj.get_selected_btn()
txt = obj.get_btn_text(id)
if txt == lv.SYMBOL.NEW_LINE:
print('in new line')
# does not work with v9 simulator
scr = lv.scr_act()
# this does
# scr = lv.screen_active()
# Password textarera
pwd = lv.textarea(scr)
pwd.set_one_line(True)
pwd.set_width(230)
pwd.set_pos(5, 120)
pwd.add_state(lv.STATE.FOCUSED)
# Keyboard
kb = lv.keyboard(scr)
kb.align(lv.ALIGN.BOTTOM_MID, 0, 0)
kb.set_map(lv.keyboard.MODE.TEXT_LOWER, LC_MAP, CTRL_LC)
kb.set_map(lv.keyboard.MODE.TEXT_UPPER, UC_MAP, CTRL_UC)
kb.set_map(lv.keyboard.MODE.SPECIAL, SP_MAP, CTRL_SP)
kb.set_mode(lv.keyboard.MODE.TEXT_LOWER)
kb.add_event(kb_cb, lv.EVENT.PRESSED, None)
kb.set_textarea(pwd)
Using lv_micropython Master…
MicroPython v1.20.0-700-g841ece132-dirty on 2023-12-01; ESP32 module 4MB(spiram) with ESP32
cr = lv.scr_act() works for my workstation. but not on v9 simulator
MicroPython v1.20.0-1050-g348432dc1-dirty on 2023-11-27; JS with Emscripten
and scr = lv.screen_active() work for simulator but not workstation?
I hope the backtrace helps… again any thought wecome !!!
