Missing regular keypresses when using evdev
Setting up the evdev driver to get keyboard presses seems only to support navigation and deletion of text?
When looking into
_evdev_process_key from lv_evdev.c
static int _evdev_process_key(uint16_t code)
switch(code) {
case KEY_UP:
return LV_KEY_UP;
case KEY_DOWN:
return LV_KEY_DOWN;
case KEY_RIGHT:
return LV_KEY_RIGHT;
case KEY_LEFT:
return LV_KEY_LEFT;
case KEY_ESC:
return LV_KEY_ESC;
case KEY_DELETE:
return LV_KEY_DEL;
case KEY_BACKSPACE:
return LV_KEY_BACKSPACE;
case KEY_ENTER:
return LV_KEY_ENTER;
case KEY_NEXT:
case KEY_TAB:
return LV_KEY_NEXT;
case KEY_PREVIOUS:
return LV_KEY_PREV;
case KEY_HOME:
return LV_KEY_HOME;
case KEY_END:
return LV_KEY_END;
default:
return 0;
Default action is to return 0 if none of the basic navigation keys.
Am I missing something or am i using the driver wrongly?
Arm SOC with GCC 8.4.0
Version 9.2
Receive keyboard input using the evdev driver.
Code used
static void setup(void)
const char *device = getenv("LV_LINUX_FBDEV_DEVICE")?:"/dev/fb0";
lv_display_t * disp = lv_linux_fbdev_create();
lv_linux_fbdev_set_file(disp, device);
/* Register input */
lv_group_t *g = lv_group_create();
lv_group_set_default(g);
lv_indev_t* keyboard = lv_evdev_create(LV_INDEV_TYPE_KEYPAD, "/dev/input/by-path/platform-gpio-keys-event");
lv_indev_set_group(keyboard, lv_group_get_default());
static void KeypressCB(lv_event_t *ev)
lv_event_code_t code = lv_event_get_code(ev);
uint32_t key = lv_event_get_key(ev);
printf("Got key: %d\n",key);
switch(key)
case 27: // esc
uv_stop(uv_default_loop());
break;
default:
break;
void LVHandler(uv_timer_t *timer)
lv_timer_handler();
int main(int argc, char *argv[])
uv_loop_t *loop = uv_default_loop();
setup();
// Setup keyboard
lv_group_add_obj(lv_group_get_default(), lv_screen_active());
evdsc = lv_obj_add_event_cb(lv_screen_active(), KeypressCB, LV_EVENT_KEY, nullptr);
lv_group_focus_obj(lv_screen_active());
uv_timer_t timer;
uv_timer_init(loop, &timer);
uv_timer_start(&timer, LVHandler, 5,5);
widgetmanager->Cycle();
uv_run(loop, UV_RUN_DEFAULT );
uv_loop_close(loop);
return 0;
