using the keyboard, I saw a “strange” behavior on the ok … (apply) pressure only when I was in “special characters” mode.
I changed the code part below by putting it equal to:
lv_kb_ctrl_uc_map
lv_kb_ctrl_lc_map
from
static const lv_btnm_ctrl_t kb_ctrl_spec_map[] = {
1, 1, 1, 1, 1, 1, 1, 1, 1, 1, LV_KB_CTRL_BTN_FLAGS | 2,
LV_KB_CTRL_BTN_FLAGS | 2, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1,
LV_KB_CTRL_BTN_FLAGS | 2, LV_KB_CTRL_BTN_FLAGS | 2, 6, 2, 2};
to
LV_KB_CTRL_BTN_FLAGS | 2, 2, 6, 2, LGL_KB_CTRL_BTN_FLAGS | 2};
the keyboard layout, in the last line, would look the same in all three cases.
With this change everything works correctly.
Did I do the right thing or did I do anything wrong in handling events?
Thanks
Walter
