I am newbie in LVGL and I trying to do an project which has 3 screen. First screen is homepage second one is menu(This is not important for now) and the last one is settings. I defined keyboard and a textarea inside settings screen. When I write something on keyboad I want textarea on both homepage and settings to show it and save what I write. The code that I write it works at the first time but then when I go back to settings from homepage I see “Text area” on text area and I see random variables on text area inside homepage. I want the string that I write on keyboard to be saved inside the variable named str. Then str is shown on homepage and be default value of textarea that inside settings.
Note: I am using stm32f4 discovery, vs code and platform IO.
#include <stdio.h>
#if LV_USE_BTN
//#if LV_USE_CB
#if LV_USE_TEXTAREA && LV_USE_KEYBOARD
static uint8_t x = 10;
static uint8_t y = 10;
bool t = false;
lv_obj_t * kb;
lv_obj_t * ta1;
const char * str= "s";
static void ta_event_cb(lv_obj_t * ta, lv_event_t event);
//Artırma azaltma fonksiyonlari
void x_artirma(lv_obj_t *btn, lv_event_t event){
if (event == LV_EVENT_CLICKED)
x++;
sttings(NULL,NULL);
void x_azaltma(lv_obj_t *btn, lv_event_t event){
x--;
sttings(NULL,NULL);
void y_artirma(lv_obj_t *btn, lv_event_t event){
y++;
sttings(NULL,NULL);
void y_azaltma(lv_obj_t *btn, lv_event_t event){
y--;
sttings(NULL,NULL);
static void cbx_fonksiyonu(lv_obj_t * obj, lv_event_t event)
if (event == LV_EVENT_VALUE_CHANGED){
if(t==true){
t=false;
else if(t==false){
t=true;
sttings(NULL,NULL);
void Anasayfaya_don(lv_obj_t *btn, lv_event_t event){
lv_obj_del(lv_scr_act());
hpage();
static void Menuye_git(lv_obj_t *btn, lv_event_t event){
lv_obj_t *scr2 = lv_obj_create(NULL, NULL);
lv_scr_load(scr2);
lv_obj_t * label1 = lv_label_create(scr2, NULL);
lv_label_set_text(label1, "MENU"); //label ismi
lv_obj_align(label1, NULL, LV_ALIGN_CENTER, 0, -140); //label konumu
lv_obj_t * menu_buton = lv_btn_create(scr2, NULL);
lv_obj_set_event_cb(menu_buton, Anasayfaya_don); //fonksiyon çağırma
lv_obj_align(menu_buton, NULL, LV_ALIGN_CENTER, 0, 30);
lv_obj_set_size(menu_buton, 120, 50);
lv_obj_t * label = lv_label_create(menu_buton, NULL);
lv_label_set_text(label, "Geri");
void sttings(lv_obj_t *btn, lv_event_t event){
if(event == LV_EVENT_RELEASED) {
lv_obj_t *scr3 = lv_obj_create(NULL, NULL);
lv_scr_load(scr3);
lv_obj_t * label1 = lv_label_create(scr3, NULL);
lv_label_set_text(label1, "AYARLAR"); //label ismi
//X
lv_obj_t * xl = lv_label_create(scr3, NULL);
lv_label_set_text_fmt(xl, "X: %d", x); //label ismi
lv_obj_align(xl, NULL, LV_ALIGN_CENTER, 0, -100); //label konumu
//artı butonu
lv_obj_t * btn_arti_x = lv_btn_create(scr3, NULL);
lv_obj_set_event_cb(btn_arti_x, x_artirma); //fonksiyon çağırma
lv_obj_align(btn_arti_x, NULL, LV_ALIGN_CENTER, 130, -100); //konum ayarlama
lv_obj_set_size(btn_arti_x, 40, 40); //buton boyutu
lv_obj_t * label3 = lv_label_create(btn_arti_x, NULL);
lv_label_set_text(label3, "+");
//eksi butonu
lv_obj_t * btn_eksi_x = lv_btn_create(scr3, NULL);
lv_obj_set_event_cb(btn_eksi_x, x_azaltma); //fonksiyon çağırma
lv_obj_align(btn_eksi_x, NULL, LV_ALIGN_CENTER, 80, -100); //konum ayarlama
lv_obj_set_size(btn_eksi_x, 40, 40); //buton boyutu
lv_obj_t * label4 = lv_label_create(btn_eksi_x, NULL);
lv_label_set_text(label4, "-");
//Y
lv_obj_t * yl = lv_label_create(scr3, NULL);
lv_label_set_text_fmt(yl, "Y: %d", y); //label ismi
lv_obj_align(yl, NULL, LV_ALIGN_CENTER, 0, -60); //label konumu
//artı butonu
lv_obj_t * btn_arti_y = lv_btn_create(scr3, NULL);
lv_obj_set_event_cb(btn_arti_y, y_artirma); //fonksiyon çağırma
lv_obj_align(btn_arti_y, NULL, LV_ALIGN_CENTER, 130, -60); //konum ayarlama
lv_obj_set_size(btn_arti_y, 40, 40); //buton boyutu
lv_obj_t * label5 = lv_label_create(btn_arti_y, NULL);
lv_label_set_text(label5, "+");
//eksi butonu
lv_obj_t * btn_eksi_y = lv_btn_create(scr3, NULL);
lv_obj_set_event_cb(btn_eksi_y, y_azaltma); //fonksiyon çağırma
lv_obj_align(btn_eksi_y, NULL, LV_ALIGN_CENTER, 80, -60); //konum ayarlama
lv_obj_set_size(btn_eksi_y, 40, 40); //buton boyutu
lv_obj_t * label6 = lv_label_create(btn_eksi_y, NULL);
lv_label_set_text(label6, "-");
//Checkbox
lv_obj_t * cb1 = lv_checkbox_create(scr3, NULL);
lv_checkbox_set_checked(cb1, t);
lv_obj_align(cb1, NULL, LV_ALIGN_CENTER, -40, -60); //checkbox konumu
lv_checkbox_set_text(cb1, " "); //checkbox yazısı
lv_obj_set_event_cb(cb1, cbx_fonksiyonu); //checkbox callback
lv_obj_t * cbl = lv_label_create(scr3, NULL);
// lv_label_set_text(cbl, "T: "); //label ismi
// lv_obj_align(cbl, NULL, LV_ALIGN_CENTER, -40, -55); //label konumu
//Text
lv_obj_t *ta1 = lv_textarea_create(scr3, NULL); //text yaratma
lv_obj_set_size(ta1, 100, 30); //boyut ayarlama
lv_obj_align(ta1, NULL, LV_ALIGN_CENTER, 0, -10); //konum ayarlama
lv_obj_set_event_cb(ta1, ta_event_cb);
//klavye
kb = lv_keyboard_create(scr3, NULL);
lv_keyboard_set_textarea(kb, ta1);
lv_keyboard_set_cursor_manage(kb, true);
//geri butonu
lv_obj_t * ayarlar_buton = lv_btn_create(scr3, NULL);
lv_obj_set_event_cb(ayarlar_buton, Anasayfaya_don); //fonksiyon çağırma
lv_obj_align(ayarlar_buton, NULL, LV_ALIGN_CENTER, -40, -100); //konum
lv_obj_set_size(ayarlar_buton, 50, 40);//buton boyutu
//lv_checkbox_set_checked(cb, t);
lv_obj_t * label = lv_label_create(ayarlar_buton, NULL);
void hpage(){
lv_obj_t *scr1 = lv_obj_create(NULL, NULL);
lv_scr_load(scr1);
lv_obj_t * label1 = lv_label_create(scr1, NULL);
lv_label_set_text(label1, "ANASAYFA"); //label ismi
//X
lv_obj_t * xl = lv_label_create(scr1, NULL);
lv_obj_align(xl, NULL, LV_ALIGN_CENTER, 0, -120); //label konumu
//Y
lv_obj_t * yl = lv_label_create(scr1, NULL);
lv_obj_align(yl, NULL, LV_ALIGN_CENTER, 0, -100); //label konumu
//T
lv_obj_t * tl = lv_label_create(scr1, NULL);
lv_label_set_text_fmt(tl, "T: %d", t); //label ismi
lv_obj_align(tl, NULL, LV_ALIGN_CENTER, 0, -80); //label konumu
//Text
lv_obj_t * tex = lv_label_create(scr1, NULL);
lv_label_set_text_fmt(tex, "Z: %s ", str); //label ismi
lv_obj_align(tex, NULL, LV_ALIGN_CENTER, 0, -60); //label konumu
// lv_obj_t * mtnl = lv_label_create(scr1, NULL);
// lv_obj_align(mtnl, NULL, LV_ALIGN_CENTER, 20, -60);
//Menü butonu
lv_obj_t * btn1 = lv_btn_create(scr1, NULL);
lv_obj_set_event_cb(btn1, Menuye_git); //fonksiyon çağırma
lv_obj_align(btn1, NULL, LV_ALIGN_CENTER, 0, 30);
lv_obj_set_size(btn1, 120, 50);
lv_obj_t * label2 = lv_label_create(btn1, NULL);
lv_label_set_text(label2, "Menu");
//Ayarlar butonu
lv_obj_t * btn2 = lv_btn_create(scr1, NULL);
lv_obj_set_event_cb(btn2, sttings); //fonksiyon çağırma
lv_obj_align(btn2, NULL, LV_ALIGN_CENTER, 0, 100); //konum ayarlama
lv_obj_set_size(btn2, 120, 50); //buton boyutu
lv_obj_t * label3 = lv_label_create(btn2, NULL);
lv_label_set_text(label3, "Ayarlar");
if( event == LV_EVENT_VALUE_CHANGED)
str = lv_textarea_get_text(ta);
sttings(NULL, NULL);
//#endif
