Hi all,
I am currently trying to set up a web based simulator for a device I am building. This is all very new to me but my understanding is that the best way to achieve this is via the javascript port. To this end I have been trying to build it but have run into a few issues. As a side note I have successfully built both the unix and esp32 ports.
When following the instructions I run into issues at different points depending on what route I take.
1) Using branch: lvgl_javascript
Using this branch I seem to run into some issues when running git submodule update --init --recursive
Prior to running this command I had run git submodule deinit --all -f To ensure I was working from a blank slate.
Upon running this i get the following issues:
fatal: could not get a repository handle for submodule 'hw/mcu/nxp'
fatal: not a git repository: /home/*****/Workspace/espy_dive_docker/micropython/lib/pico-sdk/lib/tinyusb/hw/mcu/nxp/../../../../../../../../.git/modules/micropython/modules/lib/pico-sdk/modules/tinyusb/modules/hw/mcu/nxp
Unable to fetch in submodule path 'lib/pico-sdk/lib/tinyusb/hw/mcu/nxp'
Fetched in submodule path 'lib/pico-sdk/lib/tinyusb/hw/mcu/nxp', but it did not contain b618cb1d521cc9e133bdcd0fca154dee2d925dfe. Direct fetching of that commit failed.
Failed to recurse into submodule path 'lib/pico-sdk/lib/tinyusb'
Submodule path 'lib/stm32lib': checked out '302c52794d2f579903f4e49cbad1f5d3a7f401ad'
Submodule path 'lib/tinyusb': checked out 'a6b916ba85bef6aad50f1652532b02984dfe2484'
fatal: not a git repository: /home/*****/Workspace/espy_dive_docker/micropython/lib/tinyusb/hw/mcu/nxp/../../../../../../.git/modules/micropython/modules/lib/tinyusb/modules/hw/mcu/nxp
Failed to clone 'hw/mcu/nxp'. Retry scheduled
BUG: submodule considered for cloning, doesn't need cloning any more?
Submodule path 'lib/tinyusb/hw/mcu/microchip': checked out '66b5a11995025426224e0ba6f377322e6e8893b6'
Submodule path 'lib/tinyusb/hw/mcu/microchip/samd/asf4': checked out '039b5f3bbc3f4ba4421e581db290560d59fef625'
Submodule path 'lib/tinyusb/hw/mcu/nordic/nrfx': checked out '7a4c9d946cf1801771fc180acdbf7b878f270093'
Submodule path 'lib/tinyusb/hw/mcu/nuvoton': checked out 'dc96fff794d14818c93ea1d4d760d51a014d70c5'
Unable to fetch in submodule path 'lib/tinyusb/hw/mcu/nxp'
Fetched in submodule path 'lib/tinyusb/hw/mcu/nxp', but it did not contain b618cb1d521cc9e133bdcd0fca154dee2d925dfe. Direct fetching of that commit failed.
Failed to recurse into submodule path 'lib/pico-sdk'
Failed to recurse into submodule path 'lib/tinyusb'
I then get errors when running make -C ports/javascript/
2) Using branch: lvgl_javascript
Using this branch I used the same steps as previously and this time have no errors with initialising the sub modules
This time I get the following error when running make -C ports/javascript/
make: Entering directory '/home/*****/Workspace/espy_dive_docker/micropython/ports/javascript'
************ lvgl_javascript version ************
Use make V=1 or set BUILD_VERBOSE in your environment to increase build verbosity.
Warning: FROZEN_DIR is deprecated in favour of FROZEN_MANIFEST
LVGL-GEN build/lvgl/lv_mpy.c
cp ../../lib/lv_bindings/driver/png/lodepng/lodepng.cpp build/lodepng/lodepng.c
LODEPNG-GEN build/lodepng/mp_lodepng.c
GEN build/genhdr/mpversion.h
GEN build/genhdr/moduledefs.h
GEN build/genhdr/qstr.i.last
File "/home/*****/Workspace/emsdk/emscripten/1.38.31/emcc.py", line 3308, in <module>
sys.exit(run(sys.argv))
File "/home/*****/Workspace/emsdk/emscripten/1.38.31/emcc.py", line 763, in run
options, settings_changes, newargs = parse_args(newargs)
File "/home/*****/Workspace/emsdk/emscripten/1.38.31/emcc.py", line 2343, in parse_args
options.debug_level = validate_arg_level(requested_level, 4, 'Invalid debug level: ' + newargs[i])
File "/home/*****/Workspace/emsdk/emscripten/1.38.31/emcc.py", line 3302, in validate_arg_level
raise Exception(err_msg)
Exception: Invalid debug level: -gsource-map
File "../../py/makeqstrdefs.py", line 188, in <module>
preprocess()
File "../../py/makeqstrdefs.py", line 62, in preprocess
for output in p.imap(pp(flags), chunks):
File "/usr/lib/python3.7/multiprocessing/pool.py", line 748, in next
raise value
File "/usr/lib/python3.7/multiprocessing/pool.py", line 121, in worker
result = (True, func(*args, **kwds))
File "../../py/makeqstrdefs.py", line 46, in run
return subprocess.check_output(args.pp + flags + files)
File "/usr/lib/python3.7/subprocess.py", line 395, in check_output
**kwargs).stdout
File "/usr/lib/python3.7/subprocess.py", line 487, in run
output=stdout, stderr=stderr)
subprocess.CalledProcessError: Command '['emcc', '-x', 'c', '-E', '-D__CPP__', '-D__EMSCRIPTEN__', '-std=gnu99', '-Wall', '-Wno-error', '-Wdouble-promotion', '-Wfloat-conversion', '-O3', '-DNDEBUG', '-gsource-map', '-I../../lib/lv_bindings', '-I../../lib/lv_bindings/driver/png/lodepng', '-I.', '-I../..', '-Ibuild', '-fdata-sections', '-ffunction-sections', '-Wno-unused-function', '-DLODEPNG_NO_COMPILE_ENCODER', '-DLODEPNG_NO_COMPILE_DISK', '-DLODEPNG_NO_COMPILE_ALLOCATORS', '-DFFCONF_H="lib/oofatfs/ffconf.h"', '-DMICROPY_MODULE_FROZEN_STR', '-DNO_QSTR', '../../lib/lv_bindings/lvgl/src/core/lv_disp.c', '../../lib/lv_bindings/lvgl/src/core/lv_event.c', '../../lib/lv_bindings/lvgl/src/core/lv_group.c', '../../lib/lv_bindings/lvgl/src/core/lv_indev.c', '../../lib/lv_bindings/lvgl/src/core/lv_indev_scroll.c', '../../lib/lv_bindings/lvgl/src/core/lv_obj.c', '../../lib/lv_bindings/lvgl/src/core/lv_obj_class.c', '../../lib/lv_bindings/lvgl/src/core/lv_obj_draw.c', '../../lib/lv_bindings/lvgl/src/core/lv_obj_pos.c', '../../lib/lv_bindings/lvgl/src/core/lv_obj_scroll.c', '../../lib/lv_bindings/lvgl/src/core/lv_obj_style.c', '../../lib/lv_bindings/lvgl/src/core/lv_obj_style_gen.c', '../../lib/lv_bindings/lvgl/src/core/lv_obj_tree.c', '../../lib/lv_bindings/lvgl/src/core/lv_refr.c', '../../lib/lv_bindings/lvgl/src/core/lv_theme.c', '../../lib/lv_bindings/lvgl/src/draw/lv_draw_arc.c', '../../lib/lv_bindings/lvgl/src/draw/lv_draw_blend.c', '../../lib/lv_bindings/lvgl/src/draw/lv_draw_img.c', '../../lib/lv_bindings/lvgl/src/draw/lv_draw_label.c', '../../lib/lv_bindings/lvgl/src/draw/lv_draw_line.c', '../../lib/lv_bindings/lvgl/src/draw/lv_draw_mask.c', '../../lib/lv_bindings/lvgl/src/draw/lv_draw_rect.c', '../../lib/lv_bindings/lvgl/src/draw/lv_draw_triangle.c', '../../lib/lv_bindings/lvgl/src/draw/lv_img_buf.c', '../../lib/lv_bindings/lvgl/src/draw/lv_img_cache.c', '../../lib/lv_bindings/lvgl/src/draw/lv_img_decoder.c', '../../lib/lv_bindings/lvgl/src/extra/layouts/flex/lv_flex.c', '../../lib/lv_bindings/lvgl/src/extra/layouts/grid/lv_grid.c', '../../lib/lv_bindings/lvgl/src/extra/libs/bmp/lv_bmp.c', '../../lib/lv_bindings/lvgl/src/extra/libs/freetype/lv_freetype.c', '../../lib/lv_bindings/lvgl/src/extra/libs/fsdrv/lv_fs_fatfs.c', '../../lib/lv_bindings/lvgl/src/extra/libs/fsdrv/lv_fs_posix.c', '../../lib/lv_bindings/lvgl/src/extra/libs/fsdrv/lv_fs_stdio.c', '../../lib/lv_bindings/lvgl/src/extra/libs/fsdrv/lv_fs_win32.c', '../../lib/lv_bindings/lvgl/src/extra/libs/gif/gifdec.c', '../../lib/lv_bindings/lvgl/src/extra/libs/gif/lv_gif.c', '../../lib/lv_bindings/lvgl/src/extra/libs/png/lodepng.c', '../../lib/lv_bindings/lvgl/src/extra/libs/png/lv_png.c', '../../lib/lv_bindings/lvgl/src/extra/libs/qrcode/lv_qrcode.c', '../../lib/lv_bindings/lvgl/src/extra/libs/qrcode/qrcodegen.c', '../../lib/lv_bindings/lvgl/src/extra/libs/rlottie/lv_rlottie.c', '../../lib/lv_bindings/lvgl/src/extra/libs/sjpg/lv_sjpg.c', '../../lib/lv_bindings/lvgl/src/extra/libs/sjpg/tjpgd.c', '../../lib/lv_bindings/lvgl/src/extra/lv_extra.c', '../../lib/lv_bindings/lvgl/src/extra/others/snapshot/lv_snapshot.c', '../../lib/lv_bindings/lvgl/src/extra/themes/basic/lv_theme_basic.c', '../../lib/lv_bindings/lvgl/src/extra/themes/default/lv_theme_default.c', '../../lib/lv_bindings/lvgl/src/extra/themes/mono/lv_theme_mono.c', '../../lib/lv_bindings/lvgl/src/extra/widgets/animimg/lv_animimg.c', '../../lib/lv_bindings/lvgl/src/extra/widgets/calendar/lv_calendar.c', '../../lib/lv_bindings/lvgl/src/extra/widgets/calendar/lv_calendar_header_arrow.c', '../../lib/lv_bindings/lvgl/src/extra/widgets/calendar/lv_calendar_header_dropdown.c', '../../lib/lv_bindings/lvgl/src/extra/widgets/chart/lv_chart.c', '../../lib/lv_bindings/lvgl/src/extra/widgets/colorwheel/lv_colorwheel.c', '../../lib/lv_bindings/lvgl/src/extra/widgets/imgbtn/lv_imgbtn.c', '../../lib/lv_bindings/lvgl/src/extra/widgets/keyboard/lv_keyboard.c', '../../lib/lv_bindings/lvgl/src/extra/widgets/led/lv_led.c', '../../lib/lv_bindings/lvgl/src/extra/widgets/list/lv_list.c']' returned non-zero exit status 1.
make: *** [../../py/mkrules.mk:105: build/genhdr/qstr.i.last] Error 1
make: *** Deleting file 'build/genhdr/qstr.i.last'
make: Leaving directory '/home/*****/Workspace/espy_dive_docker/micropython/ports/javascript'
If anyone knows what might be causing this then I would really appreciate it.
Thanks
