Firstly - thanks for developing and sharing such a powerful and usable piece of software.
The issue I’m having is trouble rendering widgets more complex than simple squares. For example, the screenshot should be rendering a rounded corner box, size 20 text saying hello world, and a line meter in the top left. When I paint the screen one color or draw a plain object (shaped as a rectangle), both the color and shape render perfectly.
TI TMS320F28379D (on a LAUNCHXL-F28379D Delfino dev board) using a TI C2000 compiler.
What do you experience?
Strange artifacts, omissions, and incorrect shapes.
What do you expect?
Please see the screenshot below.
static void hello_world(void) {
/*Create a Label on the currently active screen*/
lv_obj_t *label1 = lv_label_create(lv_scr_act(), NULL);
/*Modify the Label's text*/
lv_label_set_text(label1, "Hello world!");
static lv_style_t text_style;
lv_style_init(&text_style);
lv_style_set_text_color(&text_style, LV_STATE_DEFAULT, lv_color_hex(0xff3a43));
lv_obj_add_style(label1, LV_LABEL_PART_MAIN, &text_style);
/* Align the Label to the center
* NULL means align on parent (which is the screen now)
* 0, 0 at the end means an x, y offset after alignment*/
lv_obj_align(label1, NULL, LV_ALIGN_CENTER, 0, 0);
void test_box(void)
static lv_style_t style;
lv_style_init(&style);
/*Make a gradient*/
lv_style_set_bg_opa(&style, LV_STATE_DEFAULT, LV_OPA_COVER);
lv_style_set_bg_color(&style, LV_STATE_DEFAULT, LV_COLOR_TEAL);
lv_style_set_border_width(&style, LV_STATE_DEFAULT, 0);
lv_style_set_radius(&style, LV_STATE_DEFAULT, 50);
/*Create an object with the new style*/
lv_obj_t * obj = lv_obj_create(lv_scr_act(), NULL);
lv_obj_add_style(obj, LV_OBJ_PART_MAIN, &style);
lv_obj_align(obj, NULL, LV_ALIGN_CENTER, 0, 0);
lv_obj_set_size(obj, 80, 180);
void make_line_meter(lv_obj_t * container, const char* label_text, const int value, const char* value_label) {
* Create a top-level object
lv_obj_t * top_object = lv_obj_create(container, NULL);
const lv_coord_t width = 65;
const lv_coord_t height = 70;
//lv_obj_set_size(top_object, width, height);
lv_obj_set_width(top_object, width);
lv_obj_set_height(top_object, height);
static lv_style_t top_object_style;
lv_style_init(&top_object_style);
lv_style_set_border_width(&top_object_style, LV_STATE_DEFAULT, 0);
lv_style_set_shadow_width(&top_object_style, LV_STATE_DEFAULT, 0);
lv_obj_add_style(top_object, LV_OBJ_PART_MAIN, &top_object_style);
//lv_obj_align(top_object, container, LV_ALIGN_CENTER);
* Create and style the label object
lv_obj_t * label_object = lv_label_create(top_object, NULL);
lv_label_set_text(label_object, label_text);
static lv_style_t label_style;
lv_style_init(&label_style);
lv_style_set_text_font(&label_style, LV_STATE_DEFAULT, &lv_font_montserrat_12);
lv_obj_add_style(label_object, LV_LABEL_PART_MAIN, &label_style);
const lv_coord_t label_x_offset = 0;
const lv_coord_t label_y_offset = -25;
lv_obj_align(label_object, top_object, LV_ALIGN_CENTER, label_x_offset, label_y_offset);
* Create and style the line meter object
const int meter_size = 60;
lv_obj_t * meter_object = lv_linemeter_create(top_object, NULL);
lv_obj_set_width(meter_object, meter_size);
lv_obj_set_height(meter_object, meter_size);
lv_linemeter_set_value(meter_object, value);
const lv_coord_t meter_x_offset = 0;
const lv_coord_t meter_y_offset = 20;
lv_obj_align(meter_object, top_object, LV_ALIGN_CENTER, meter_x_offset, meter_y_offset);
static lv_style_t meter_style;
lv_style_init(&meter_style);
lv_style_set_border_width(&meter_style, LV_STATE_DEFAULT, 0);
lv_style_set_line_width(&meter_style, LV_STATE_DEFAULT, 3);
lv_style_set_scale_end_line_width(&meter_style, LV_STATE_DEFAULT, 2);
lv_style_set_scale_width(&meter_style, LV_STATE_DEFAULT, 10);
const int pad = 1;
lv_style_set_pad_top(&meter_style, LV_STATE_DEFAULT, pad);
lv_style_set_pad_left(&meter_style, LV_STATE_DEFAULT, pad);
lv_style_set_pad_right(&meter_style, LV_STATE_DEFAULT, pad);
lv_obj_add_style(meter_object, LV_LINEMETER_PART_MAIN, &meter_style);
* Create and style the value label object
lv_obj_t * value_label_object = lv_label_create(top_object, NULL);
lv_label_set_text(value_label_object, value_label);
static lv_style_t value_label_style;
lv_style_init(&value_label_style);
lv_style_set_text_font(&value_label_style, LV_STATE_DEFAULT, &lv_font_montserrat_12);
lv_obj_add_style(value_label_object, LV_LABEL_PART_MAIN, &value_label_style);
const lv_coord_t value_label_x_offset = LV_DPX(0);
const lv_coord_t value_label_y_offset = LV_DPX(35);
lv_obj_align(value_label_object, top_object, LV_ALIGN_CENTER, value_label_x_offset, value_label_y_offset);
void ui_init() {
test_box();
hello_world();
make_line_meter(lv_scr_act(), "Tb", 50, "34C");
