Hi there,
I’m trying to port LVGL to be used with a STM32F407 (on the STM32F4-DISCO board), and had success after following the porting guide and using the less efficient flush_cb that writes pixel by pixel to memory. When I later try to use DMA, and do as in the lv_port_stm32F429_disco repository, I can see how first screen is written to the display, but not all of it (20-30 lines left, which keep random noise).
After this point, if I try to write some more objects to the display, nothing else shows up
STM32F407, STM32F4-DISCO, gcc, LVGL 7.1, and ILI9325 320x240 Display
Port LVGL to this MCU + Display, using DMA buffer transfer
I tried to write to the display pixel by pixel, manually copying the lvgl buffer to the display buffer, with successful results:
static void my_flush_cb(lv_disp_drv_t *disp_drv, const lv_area_t *area, lv_color_t *color_p) {
int32_t x, y;
for (y = area->y1; y <= area->y2; y++) {
for (x = area->x1; x <= area->x2; x++) {
ili9325_WritePixel(x, y, color_p->full);
color_p++;
But when I configure it to use DMA, the display is not showing the image on the whole surface, showing random data on the last 20 - 30 lines, and the data is updated no more, as if it would be writing to a wrong memory place and device display would halt. (Program in MCU continues)
static __IO uint16_t * my_fb = (__IO uint16_t *) 0x60020000;
static int32_t x1_flush;
static int32_t y1_flush;
static int32_t x2_flush;
static int32_t y2_fill;
static int32_t y_fill_act;
static lv_color_t *buf_to_flush;
/*Return if the area is out the screen*/
if (area->x2 < 0) return;
if (area->y2 < 0) return;
if (area->x1 > DISP_HOR_RES - 1) return;
if (area->y1 > DISP_VER_RES - 1) return;
int32_t act_x2 = area->x2 > DISP_HOR_RES - 1 ? DISP_HOR_RES - 1 : area->x2;
int32_t act_y2 = area->y2 > DISP_VER_RES - 1 ? DISP_VER_RES - 1 : area->y2;
x1_flush = act_x1;
y1_flush = act_y1;
x2_flush = act_x2;
y2_fill = act_y2;
y_fill_act = act_y1;
buf_to_flush = color_p;
/*##-7- Start the DMA transfer using the interrupt mode #*/
/* Configure the source, destination and buffer size DMA fields and Start DMA Stream transfer */
/* Enable All the DMA interrupts */
HAL_StatusTypeDef err;
err = HAL_DMA_Start_IT(&hdma_memtomem_dma2_stream0,
(uint32_t) buf_to_flush,
(uint32_t) &my_fb[y_fill_act * DISP_HOR_RES + x1_flush],
(x2_flush - x1_flush + 1));
if (err != HAL_OK) {
while (1); /*Halt on error*/
void DMA_TransferComplete(DMA_HandleTypeDef *han) {
y_fill_act++;
if (y_fill_act > y2_fill) {
lv_disp_flush_ready(&disp_drv);
} else {
buf_to_flush += x2_flush - x1_flush + 1;
/*##-7- Start the DMA transfer using the interrupt mode ####################*/
if (HAL_DMA_Start_IT(han, (uint32_t) buf_to_flush, (uint32_t) &my_fb[y_fill_act * DISP_HOR_RES + x1_flush],
(x2_flush - x1_flush + 1)) != HAL_OK) {
void MX_DMA_Init(void)
/* DMA controller clock enable */
__HAL_RCC_DMA2_CLK_ENABLE();
/* Configure DMA request hdma_memtomem_dma2_stream0 on DMA2_Stream0 */
hdma_memtomem_dma2_stream0.Instance = DMA2_Stream0;
hdma_memtomem_dma2_stream0.Init.Channel = DMA_CHANNEL_0;
hdma_memtomem_dma2_stream0.Init.Direction = DMA_MEMORY_TO_MEMORY;
hdma_memtomem_dma2_stream0.Init.PeriphInc = DMA_PINC_ENABLE;
hdma_memtomem_dma2_stream0.Init.MemInc = DMA_MINC_ENABLE;
hdma_memtomem_dma2_stream0.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
hdma_memtomem_dma2_stream0.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
hdma_memtomem_dma2_stream0.Init.Mode = DMA_NORMAL;
hdma_memtomem_dma2_stream0.Init.Priority = DMA_PRIORITY_HIGH;
hdma_memtomem_dma2_stream0.Init.FIFOMode = DMA_FIFOMODE_ENABLE;
hdma_memtomem_dma2_stream0.Init.FIFOThreshold = DMA_FIFO_THRESHOLD_1QUARTERFULL;
hdma_memtomem_dma2_stream0.Init.MemBurst = DMA_MBURST_SINGLE;
hdma_memtomem_dma2_stream0.Init.PeriphBurst = DMA_PBURST_SINGLE;
if (HAL_DMA_Init(&hdma_memtomem_dma2_stream0) != HAL_OK)
Error_Handler();
/* DMA interrupt init */
hdma_memtomem_dma2_stream0.XferCpltCallback = DMA_TransferComplete;
/* DMA2_Stream0_IRQn interrupt configuration */
HAL_NVIC_SetPriority(DMA2_Stream0_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(DMA2_Stream0_IRQn);
void MX_FSMC_Init(void)
FSMC_NORSRAM_TimingTypeDef Timing = {0};
/** Perform the SRAM1 memory initialization sequence
hsram1.Instance = FSMC_NORSRAM_DEVICE;
hsram1.Extended = FSMC_NORSRAM_EXTENDED_DEVICE;
/* hsram1.Init */
hsram1.Init.NSBank = FSMC_NORSRAM_BANK1;
hsram1.Init.DataAddressMux = FSMC_DATA_ADDRESS_MUX_DISABLE;
hsram1.Init.MemoryType = FSMC_MEMORY_TYPE_SRAM;
hsram1.Init.MemoryDataWidth = FSMC_NORSRAM_MEM_BUS_WIDTH_16;
hsram1.Init.BurstAccessMode = FSMC_BURST_ACCESS_MODE_DISABLE;
hsram1.Init.WaitSignalPolarity = FSMC_WAIT_SIGNAL_POLARITY_LOW;
hsram1.Init.WrapMode = FSMC_WRAP_MODE_DISABLE;
hsram1.Init.WaitSignalActive = FSMC_WAIT_TIMING_BEFORE_WS;
hsram1.Init.WriteOperation = FSMC_WRITE_OPERATION_ENABLE;
hsram1.Init.WaitSignal = FSMC_WAIT_SIGNAL_DISABLE;
hsram1.Init.ExtendedMode = FSMC_EXTENDED_MODE_DISABLE;
hsram1.Init.AsynchronousWait = FSMC_ASYNCHRONOUS_WAIT_DISABLE;
hsram1.Init.WriteBurst = FSMC_WRITE_BURST_DISABLE;
hsram1.Init.PageSize = FSMC_PAGE_SIZE_NONE;
/* Timing */
Timing.AddressSetupTime = 15;
Timing.AddressHoldTime = 15;
Timing.DataSetupTime = 255;
Timing.BusTurnAroundDuration = 15;
Timing.CLKDivision = 16;
Timing.DataLatency = 17;
Timing.AccessMode = FSMC_ACCESS_MODE_A;
/* ExtTiming */
if (HAL_SRAM_Init(&hsram1, &Timing, NULL) != HAL_OK)
Error_Handler( );
Result with DMA method:
