When I use widget image_button (lv_Imgbtn) for 2 widgets,
the screen and touch interface can perform well as the following clip.
VID_20230321_195029 (jumpshare.com)
However, when I use 6 widgets of image_button and touch the image_button ,
the screen shakes as the following clip.
VID_20230321_195402 (jumpshare.com)
How to solve the issue of the screen’s shaking?
ESP32S3 TFT 5 inch (RGB Driver)
LVGL version dev7.0 ( based on version 6.x)
Normally touching is well,
but if the screen use mores widgets with touching,
sometime the screen will shake.
Use more widgets without touch using, the screen doesn’t occur the issue of screen’s shaking.
But more widgets with touch using, the screen occur the issue of screen’s shaking.
LV_IMG_DECLARE(img_background);
LV_IMG_DECLARE(img_homeplan3d_bedroom);
LV_IMG_DECLARE(img_homeplan3d_extrapart);
LV_IMG_DECLARE(img_homeplan3d_front);
LV_IMG_DECLARE(img_homeplan3d_sittingroom);
LV_IMG_DECLARE(img_homeplan3d_toilet1);
LV_IMG_DECLARE(img_homeplan3d_toilet2);
lv_obj_t* bg;
lv_obj_t* bedroom, *extrapart, *front, *sittingroom, *toilet1, *toilet2;
bg = lv_img_create(lv_scr_act(), NULL);
lv_img_set_src(bg, (void*) &img_background );
bedroom = lv_imgbtn_create(bg, NULL);
sittingroom = lv_imgbtn_create(bg, NULL);
toilet1 = lv_imgbtn_create(bg, NULL);
toilet2 = lv_imgbtn_create(bg, NULL);
extrapart = lv_imgbtn_create(bg, NULL);
front = lv_imgbtn_create(bg, NULL);
lv_btn_set_toggle(bedroom , true);
lv_btn_set_toggle(sittingroom , true);
lv_btn_set_toggle(toilet1 , true);
lv_btn_set_toggle(toilet2 , true);
lv_btn_set_toggle(extrapart , true);
lv_btn_set_toggle(front , true);
lv_imgbtn_set_src(bedroom, LV_BTN_STATE_REL ,(void*) &img_homeplan3d_bedroom );
lv_imgbtn_set_src(bedroom, LV_BTN_STATE_PR ,(void*) &img_homeplan3d_bedroom );
lv_imgbtn_set_src(bedroom, LV_BTN_STATE_TGL_REL ,(void*) &img_homeplan3d_bedroom );
lv_imgbtn_set_src(bedroom, LV_BTN_STATE_TGL_PR ,(void*) &img_homeplan3d_bedroom );
lv_imgbtn_set_src(sittingroom, LV_BTN_STATE_REL ,(void*) &img_homeplan3d_sittingroom );
lv_imgbtn_set_src(sittingroom, LV_BTN_STATE_PR ,(void*) &img_homeplan3d_sittingroom );
lv_imgbtn_set_src(sittingroom, LV_BTN_STATE_TGL_REL ,(void*) &img_homeplan3d_sittingroom );
lv_imgbtn_set_src(sittingroom, LV_BTN_STATE_TGL_PR ,(void*) &img_homeplan3d_sittingroom );
lv_imgbtn_set_src(toilet1, LV_BTN_STATE_REL ,(void*) &img_homeplan3d_toilet1 );
lv_imgbtn_set_src(toilet1, LV_BTN_STATE_PR ,(void*) &img_homeplan3d_toilet1 );
lv_imgbtn_set_src(toilet1, LV_BTN_STATE_TGL_REL ,(void*) &img_homeplan3d_toilet1 );
lv_imgbtn_set_src(toilet1, LV_BTN_STATE_TGL_PR ,(void*) &img_homeplan3d_toilet1 );
lv_imgbtn_set_src(toilet2, LV_BTN_STATE_REL ,(void*) &img_homeplan3d_toilet2 );
lv_imgbtn_set_src(toilet2, LV_BTN_STATE_PR ,(void*) &img_homeplan3d_toilet2 );
lv_imgbtn_set_src(toilet2, LV_BTN_STATE_TGL_REL ,(void*) &img_homeplan3d_toilet2 );
lv_imgbtn_set_src(toilet2, LV_BTN_STATE_TGL_PR ,(void*) &img_homeplan3d_toilet2 );
lv_imgbtn_set_src(extrapart, LV_BTN_STATE_REL ,(void*) &img_homeplan3d_extrapart );
lv_imgbtn_set_src(extrapart, LV_BTN_STATE_PR ,(void*) &img_homeplan3d_extrapart );
lv_imgbtn_set_src(extrapart, LV_BTN_STATE_TGL_REL ,(void*) &img_homeplan3d_extrapart );
lv_imgbtn_set_src(extrapart, LV_BTN_STATE_TGL_PR ,(void*) &img_homeplan3d_extrapart );
lv_imgbtn_set_src(front, LV_BTN_STATE_REL ,(void*) &img_homeplan3d_front );
lv_imgbtn_set_src(front, LV_BTN_STATE_PR ,(void*) &img_homeplan3d_front );
lv_imgbtn_set_src(front, LV_BTN_STATE_TGL_REL ,(void*) &img_homeplan3d_front );
lv_imgbtn_set_src(front, LV_BTN_STATE_TGL_PR ,(void*) &img_homeplan3d_front );
static lv_style_t style_imgbtn[5];
lv_style_copy(&style_imgbtn[0], lv_btn_get_style(bedroom, LV_BTN_STYLE_REL));
lv_style_copy(&style_imgbtn[1], lv_btn_get_style(bedroom, LV_BTN_STYLE_PR));
lv_style_copy(&style_imgbtn[2], lv_btn_get_style(bedroom, LV_BTN_STYLE_TGL_REL));
lv_style_copy(&style_imgbtn[3], lv_btn_get_style(bedroom, LV_BTN_STYLE_TGL_PR));
lv_style_copy(&style_imgbtn[4], lv_btn_get_style(bedroom, LV_BTN_STYLE_INA));
style_imgbtn[1].image.color = LV_COLOR_BLACK; // Pressed
style_imgbtn[1].image.intense = 160;
style_imgbtn[2].image.color = LV_COLOR_BLACK; // Toggel Released
style_imgbtn[2].image.intense = 200;
style_imgbtn[3].image.color = LV_COLOR_BLACK; // Toggel Pressed
style_imgbtn[3].image.intense = 160;
lv_btn_set_style(bedroom , LV_BTN_STYLE_REL, &style_imgbtn[0]);
lv_btn_set_style(bedroom , LV_BTN_STYLE_PR, &style_imgbtn[1]);
lv_btn_set_style(bedroom , LV_BTN_STYLE_TGL_REL, &style_imgbtn[2]);
lv_btn_set_style(bedroom , LV_BTN_STYLE_TGL_PR, &style_imgbtn[3]);
lv_btn_set_style(bedroom , LV_BTN_STYLE_INA, &style_imgbtn[4]);
lv_btn_set_style(sittingroom, LV_BTN_STYLE_REL, &style_imgbtn[0]);
lv_btn_set_style(sittingroom, LV_BTN_STYLE_PR, &style_imgbtn[1]);
lv_btn_set_style(sittingroom, LV_BTN_STYLE_TGL_REL, &style_imgbtn[2]);
lv_btn_set_style(sittingroom, LV_BTN_STYLE_TGL_PR, &style_imgbtn[3]);
lv_btn_set_style(sittingroom, LV_BTN_STYLE_INA, &style_imgbtn[4]);
lv_btn_set_style(toilet1 , LV_BTN_STYLE_REL, &style_imgbtn[0]);
lv_btn_set_style(toilet1 , LV_BTN_STYLE_PR, &style_imgbtn[1]);
lv_btn_set_style(toilet1 , LV_BTN_STYLE_TGL_REL, &style_imgbtn[2]);
lv_btn_set_style(toilet1 , LV_BTN_STYLE_TGL_PR, &style_imgbtn[3]);
lv_btn_set_style(toilet1 , LV_BTN_STYLE_INA, &style_imgbtn[4]);
lv_btn_set_style(toilet2 , LV_BTN_STYLE_REL, &style_imgbtn[0]);
lv_btn_set_style(toilet2 , LV_BTN_STYLE_PR, &style_imgbtn[1]);
lv_btn_set_style(toilet2 , LV_BTN_STYLE_TGL_REL, &style_imgbtn[2]);
lv_btn_set_style(toilet2 , LV_BTN_STYLE_TGL_PR, &style_imgbtn[3]);
lv_btn_set_style(toilet2 , LV_BTN_STYLE_INA, &style_imgbtn[4]);
lv_btn_set_style(extrapart , LV_BTN_STYLE_REL, &style_imgbtn[0]);
lv_btn_set_style(extrapart , LV_BTN_STYLE_PR, &style_imgbtn[1]);
lv_btn_set_style(extrapart , LV_BTN_STYLE_TGL_REL, &style_imgbtn[2]);
lv_btn_set_style(extrapart , LV_BTN_STYLE_TGL_PR, &style_imgbtn[3]);
lv_btn_set_style(extrapart , LV_BTN_STYLE_INA, &style_imgbtn[4]);
lv_btn_set_style(front , LV_BTN_STYLE_REL, &style_imgbtn[0]);
lv_btn_set_style(front , LV_BTN_STYLE_PR, &style_imgbtn[1]);
lv_btn_set_style(front , LV_BTN_STYLE_TGL_REL, &style_imgbtn[2]);
lv_btn_set_style(front , LV_BTN_STYLE_TGL_PR, &style_imgbtn[3]);
lv_btn_set_style(front , LV_BTN_STYLE_INA, &style_imgbtn[4]);
lv_obj_align(bedroom , NULL , LV_ALIGN_IN_TOP_LEFT , 206,65);
lv_obj_align(sittingroom , bedroom , LV_ALIGN_OUT_BOTTOM_LEFT , 0, 0);
lv_obj_align(toilet1 , bedroom , LV_ALIGN_OUT_RIGHT_TOP , 0, 0);
lv_obj_align(toilet2 , toilet1 , LV_ALIGN_OUT_BOTTOM_RIGHT , 0, 0);
lv_obj_align(extrapart , toilet1 , LV_ALIGN_OUT_BOTTOM_LEFT , 0, 0);
lv_obj_align(front , sittingroom , LV_ALIGN_OUT_RIGHT_BOTTOM , 0, 0);
as the upper clips. and the following screenshot.
