Facing issue in setting Opacity to an image object in the project generated by squareline studio.
With the opacity value less than 255, the object hides instead of being transparent.
The same code works in a squareline simulator.
We are using 16-bit swap color depth.
ESP32S3
v8.3.0
Set the opacity to an image object to be displayed as pressed.
We have tried to set different opacity values and found the object gets hidden for a value less than 255.
Add a code snippet that can run in the simulator. It should contain only the relevant code that compiles without errors when separated from your main code base.
lv_obj_set_style_opa(target, val, 0);
