Is there a way to add a checked box dynamically
ESP32 S3
v8.3.4
Created the Initial List of Checkboxes
void init_todoList(lv_obj_t* scr,lv_obj_t* list,lv_style_t* list_style){
lv_obj_set_flex_flow(lv_scr_act(), LV_FLEX_FLOW_COLUMN);
lv_obj_set_flex_align(lv_scr_act(), LV_FLEX_ALIGN_CENTER, LV_FLEX_ALIGN_START, LV_FLEX_ALIGN_CENTER);
list = lv_obj_create(lv_scr_act());
lv_obj_set_size(list, 240, 240);
lv_obj_center(list);
lv_obj_set_flex_flow(list, LV_FLEX_FLOW_COLUMN);
lv_obj_add_event_cb(list, scroll_event_cb, LV_EVENT_SCROLL, NULL);
lv_obj_set_style_radius(list, LV_RADIUS_CIRCLE, 0);
lv_obj_set_style_clip_corner(list, true, 0);
lv_obj_set_scroll_dir(list, LV_DIR_VER);
lv_obj_set_scroll_snap_y(list, LV_SCROLL_SNAP_CENTER);
lv_obj_set_scrollbar_mode(list, LV_SCROLLBAR_MODE_OFF);
uint32_t i;
for(i = 0; i < 5; i++) {
todoList_check_boxes = lv_checkbox_create(list);
lv_checkbox_set_text(todoList_check_boxes, "Apple");
// lv_obj_add_event_cb(cb, event_handler, LV_EVENT_ALL, NULL);
lv_obj_t * btn = lv_btn_create(list);
lv_obj_set_width(btn, lv_pct(200));
lv_obj_add_event_cb(btn, add_button_pressed, LV_EVENT_CLICKED, NULL);
lv_obj_t * label = lv_label_create(btn);
lv_label_set_text_fmt(label,"Add Event");
/*Update the buttons position manually for first*/
lv_event_send(list, LV_EVENT_SCROLL, NULL);
/*Be sure the fist button is in the middle*/
lv_obj_scroll_to_view(lv_obj_get_child(list, 0), LV_ANIM_OFF);
void add_button_pressed(lv_event_t * e){
if(lv_event_get_code(e) == LV_EVENT_CLICKED){
todoList_check_boxes = lv_checkbox_create(todoList);
lv_checkbox_set_text(todoList_check_boxes, "Banana");
Just trying to figure how to add a new checked box to a initial list of checkboxes, wanted to do a basic to-do list but this does not add a new checkbox to the list. I tried looking through the documentation but I did not find a way (sorry if its something very trivial!). Thanks!
