elgerg
January 23, 2022, 6:39pm
1
I currently colour a table column based on a temp, red, blue and green.
Simulator but Raspberry Pi eventually
I’d like to clear an control without having to check each one first
bool chk = lv_table_has_cell_ctrl(sensorTable, arraypos, 1, LV_TABLE_CELL_CTRL_CUSTOM_1);
if(chk) lv_table_clear_cell_ctrl(sensorTable, arraypos, 1, LV_TABLE_CELL_CTRL_CUSTOM_1);
chk = lv_table_has_cell_ctrl(sensorTable, arraypos, 1, LV_TABLE_CELL_CTRL_CUSTOM_2);
if(chk) lv_table_clear_cell_ctrl(sensorTable, arraypos, 1, LV_TABLE_CELL_CTRL_CUSTOM_2);
chk = lv_table_has_cell_ctrl(sensorTable, arraypos, 1, LV_TABLE_CELL_CTRL_CUSTOM_3);
if(chk) lv_table_clear_cell_ctrl(sensorTable, arraypos, 1, LV_TABLE_CELL_CTRL_CUSTOM_3);
lv_table_add_cell_ctrl(sensorTable, arraypos, 1, outCol);
Same as above
Thanks!!
First you need clear the field of cell only if sensor change data considerably compared to an old stored value (i dont see the complete code here)
Second not need clear cell but just use a formatted output that cover all field (i think 8 chars is enough, depend how many decimal you want use)
with: voidlv_table_set_cell_value (lv_obj_t table , uint16_trow , uint16_tcol , const char *txt* )
elgerg
January 26, 2022, 6:56pm
3
here is the full code:
bool colourUpdateRequired = true;
//sensor = sensor.substring(0,11);
int arraypos = ((curserpos)/10);
if(arraypos<0)
arraypos = 0;
if(strcmp("green", json_object_get_string(colour_struct)) == 0)
printDateTime();
printf("Colour::::: %s\n", "Green");
if(lv_table_has_cell_ctrl(sensorTable, arraypos, 1, LV_TABLE_CELL_CTRL_CUSTOM_1))
colourUpdateRequired = false;
outCol = LV_TABLE_CELL_CTRL_CUSTOM_1;
if(strcmp("red", json_object_get_string(colour_struct)) == 0)
printDateTime();
printf("Colour::::: %s\n", "Red");
if(lv_table_has_cell_ctrl(sensorTable, arraypos, 1, LV_TABLE_CELL_CTRL_CUSTOM_2))
outCol = LV_TABLE_CELL_CTRL_CUSTOM_2;
if(strcmp("blue", json_object_get_string(colour_struct)) == 0)
printDateTime();
printf("Colour::::: %s\n", "Blue");
if(lv_table_has_cell_ctrl(sensorTable, arraypos, 1, LV_TABLE_CELL_CTRL_CUSTOM_3))
outCol = LV_TABLE_CELL_CTRL_CUSTOM_3;
lv_table_set_cell_value(sensorTable, arraypos, 0, json_object_get_string(sensor_struct));
if(colourUpdateRequired)
I still think that there could (should) be a better way. iE are there any flags? Clear it…
Thanks
Alex
And this is in main loop?..or is called by a timer?..and i dont know how is set LV_TABLE_CELL_CTRL_CUSTOM_x
better way for overwrite a cell is made a string that cover all cell (is enough 8 chars) and covert em in char array and overwrite old chars.
And you need consider use of a variable that read old cell value, and if variation is more that decimals, call a redraw cell routine, or is a continue screen update (also if use Json) due by variations of sensors.
