Hi, I’m working with a modified instance of a “simpledrm” kernel driver framebuffer where the only modification is it adds YUV support (so not much changes there). The plane’s only listed supported format is YUYV when checked with modetest, so I’m confident that aspect is working and I don’t believe it would be doing conversion from YUV to RGB in the driver.
The framebuffer is setup that way such that my HW will read it when it wants to but expects the data there to be YUYV (8 bit 4:2:2) format. I thought I had setup things moderately well to configure that, but noticed that there wasn’t really a way to save colours natively in YUV so I was hopeful there might be some conversion behind the scenes. From what I can deduce, the colour output into the framebuffer is instead RGB565 which produces some interesting results in YUV (pure red is seen as Y=248, U=V=0).
I suspect I need to add either a callback for conversion for weak support (calculation every time) or new colour handling and draw function support (at minimum, probably more for blending / drawing).
Xilinx ZynqUS+ running busybox, linux kernel is a fork of 6.1 LTS
9.3.0 dev
- Generally, is it possible to have it output in YUV colour space into the buffer?
- Is there a native color space change I can modify it to use (to avoid potentially costly colour space conversion at final step)?
- If not native colour space change, is there a function/setting/callback that I set/add that could convert it to YUV?
- If so, would adding it in the flush_cb
drm_flushbe the best place to do so? I recall seeing a note about something similar for swapping endianness of RGB.
lv_conf.h
#define LV_COLOR_DEPTH=16
lv_linux_drm.c
#if LV_COLOR_DEPTH == 16
#define DRM_FOURCC DRM_FORMAT_YUYV
#else
#error LV_COLOR_DEPTH not supported
then for testing, I also tried setting the display color format in my main executable before I setup any colors. No chnage.
Additional Notes
If I have to do a bit of an overhaul to get native YUV handling, I have some rudimentary specific use case ideas which can maybe jankily work in my use case since i don’t do blending.
