Inverted colors on 24-bit RGB display
I’m using 24-bit RGB display and Zephyr. Red and blue are swapped and I can’t figure out how to control that. I’m positive the display is wired correctly, and my LCD driver is set for RGB. Can someone help, at least with advise on where to look for the reason?
Any chance you’re using a BGR display? Or, try checking if your display has a bit to flip between RGB and BGR transfer order.
