I am integrating LVGL as a git submodule into my source tree. The project is based on cmake and I am using lv_conf.h in the main folder. Since the last versions, the integration fails with:
/home/werner/projects/pico-ugfx/lvgl/src/core/../lv_conf_internal.h:59:18: error: #include expects "FILENAME" or <FILENAME>
[build] #include LV_CONF_PATH /* Note: Make sure to define custom CONF_PATH as a string */
Setting of LV_CONF_PATH is in the top level CMakeLists.txt
set(LV_CONF_PATH ${CMAKE_SOURCE_DIR}/lv_conf.h)
and changing to
set(LV_CONF_PATH \"${CMAKE_SOURCE_DIR}/lv_conf.h\")
leads to many other failures like
build] CMake Warning (dev) at /home/werner/projects/pico-ugfx/build/lvgl/CMakeFiles/lvgl.dir/DependInfo.cmake:23:
[build] Syntax Warning in cmake code at column 13
How can this be solved? In the meanwhile I am modifying lv_conf_internal.h to get the project compiled, but this is no solution as it changes the local lvgl repo. I had never issues with the version v8.x
Any ideas are highly appreciated.
Thanks!
Update:
Changing lv_conf_internal.h to
#define STRINGIFY(x) #x
#define TOSTRING(x) STRINGIFY(x)
/* If lv_conf.h is not skipped, include it. */
#if !defined(LV_CONF_SKIP) || defined(LV_CONF_PATH)
#ifdef LV_CONF_PATH /* If there is a path defined for lv_conf.h, use it */
//#pragma message(">>>>>> " TOSTRING(LV_CONF_PATH))
#include TOSTRING(LV_CONF_PATH) /* Note: Make sure to define custom CONF_PATH as a string */
#elif defined(LV_CONF_INCLUDE_SIMPLE) /* Or simply include lv_conf.h is enabled. */
#include "lv_conf.h"
#else
#include "../../lv_conf.h" /* Else assume lv_conf.h is next to the lvgl folder. */
#if !defined(LV_CONF_H) && !defined(LV_CONF_SUPPRESS_DEFINE_CHECK)
/* #include will sometimes silently fail when __has_include is used */
/* https://gcc.gnu.org/bugzilla/show_bug.cgi?id=80753 */
#pragma message("Possible failure to include lv_conf.h, please read the comment in this file if you get errors")
makes the project working perfectly.
