I got some troubles when installing EdgeLine in window 10 Server, notification that this installation requires window 7,8,10. I have tried to run it in compatibility mode with window 7 or 8 but nothing change
AFAIK “Windows 10 Server” does not exist; only Windows Server 2016/2019. Is that what you mean?
The setup tool might be checking that the OS version matches an expected pattern instead of checking for the presence of features.
Window Server 2019, but what should I do to install on this OS version ?
The installer probably needs to be adjusted to allow more variants of Windows instead of just checking for standard Windows 10, but I don’t work on Edgeline so I can’t say for sure.
We haven’t tried EdgeLine on Windows Server so far.
If it’s not so complicated and there a reasonable need for it we can support Windows Servers too but I’d like to understand your use case.
Do you use a Windows Server OS on your PC? Or try to run EdgeLine remotely?
We really restricted the installed to desktop Windows variants.
I try to install on a lab server that actually runs Window Server 2019, thus the lab members can use it to use EdgeLine remotely.
