I have gotten lvgl compiled and running using the linux frame buffer with my raspberry pi 4 and the smart pi 7" touch screen. I have looked at other posts and tried what was mentioned with no luck
I am using a Raspberry Pi 4
latest master
Currently I have a button and am trying to make it to be able to be tapped, and when it is tapped to send data to another board over I2c
Currently I followed the LVGL documentation and created an lv_indev object that has the LV_INDEV_POINTER type and set a call back function for it to use. When I run the code and put a printf statement in the callback, it does print out so I know the call back is being executed. However, code never get inside the if statement that says
data->state == LV_INDEV_STATE_PRESSED
Here is my main function with a simple button, my cmake file, and my lv_conf.h
main.c
#include <unistd.h>
#include <pthread.h>
#include <time.h>
#include <stdio.h>
#include <stdlib.h>
#include "lvgl/lvgl.h"
void lv_linux_run_loop(void)
uint32_t idle_time;
/*Handle LVGL tasks*/
while(1) {
idle_time = lv_timer_handler(); /*Returns the time to the next timer execution*/
usleep(idle_time * 1000);
void search_handler(lv_event_t *event);
void input_touch_event(lv_indev_t* indev, lv_indev_data_t* data);
int main(void) {
const char *device = getenv("LV_LINUX_FBDEV_DEVICE") ? : "/dev/fb0";
lv_display_t * disp = lv_linux_fbdev_create();
lv_linux_fbdev_set_file(disp, device);
lv_obj_set_style_bg_color(lv_screen_active(), lv_color_hex(0x161c20), LV_PART_MAIN);
/* Touchpad Monitor */
lv_indev_t *indev = lv_indev_create();
lv_indev_enable(indev, true);
lv_indev_set_read_cb(indev, input_touch_event);
/* LAYOUT */
lv_obj_t* label;
lv_obj_t *searchButton = lv_button_create(lv_screen_active());
lv_obj_align(searchButton, LV_ALIGN_CENTER, 0, 0);
lv_obj_set_size(searchButton, lv_pct(20), lv_pct(10));
lv_obj_add_event_cb(searchButton, search_handler, LV_EVENT_ALL, NULL);
lv_obj_remove_flag(searchButton, LV_OBJ_FLAG_PRESS_LOCK);
lv_obj_add_flag(searchButton, LV_OBJ_FLAG_CLICKABLE);
label = lv_label_create(searchButton);
lv_label_set_text(label, "Search");
lv_obj_center(label);
/* STYLE */
static lv_style_t style;
lv_style_init(&style);
/*Set a background color and a radius*/
lv_style_set_bg_color(&style, lv_color_hex(0x2305cb));
lv_style_set_radius(&style, 25);
/*Add a shadow*/
lv_style_set_shadow_width(&style, 25);
lv_style_set_shadow_spread(&style, 1);
lv_style_set_shadow_color(&style, lv_color_white());
lv_style_set_shadow_offset_x(&style, 0);
lv_style_set_shadow_offset_y(&style, 0);
lv_obj_add_style(searchButton, &style, 0);
lv_linux_run_loop();
return 0;
void search_handler(lv_event_t *event) {
LV_LOG_USER("Clicked\n");
printf("Button Pressed\n");
void input_touch_event(lv_indev_t* indev, lv_indev_data_t* data) {
printf("Touch event %s\n", data->state);
if(data->state == LV_INDEV_STATE_PRESSED) {
printf("x: %i", data->point.x);
printf("y: %i", data->point.y);
#define LV_DEMO_EBIKE_PORTRAIT 0 /*0: for 480x270..480x320, 1: for 480x800..720x1280*/
/*--END OF LV_CONF_H--*/
#endif /*LV_CONF_H*/
Here is the layout. It’s just a simple button at the moment
