Indev drv issue
Hey there! I just started to work with LVGL and got a problem. The problem is that I am trying to create indev_drv to control the UI, but trace stops in lv_indev_read_timer_cb which is located in lv_indev.c.
void lv_indev_read_timer_cb(lv_timer_t* timer)
    INDEV_TRACE("begin");
    lv_indev_data_t data;
    indev_act = timer->user_data;
    if (indev_act->driver->disp == NULL) return;
    indev_proc_reset_query_handler(indev_act);
    if (indev_act->proc.disabled) return;
    if (indev_act->driver->disp->prev_scr != NULL) return; // <- Error here
    bool continue_reading;
The error is simple: Guru Meditation Error: Core 1 panic'ed (LoadProhibited).
Maybe error description from the official espressif site will help. Here it is:
LoadProhibited, StoreProhibited
These CPU exceptions happen when an application attempts to read from or write to an invalid memory
location. The address which has been written/read is found in the EXCVADDR register in the register
dump. If this address is zero, it usually means that the application has attempted to dereference a NULL
pointer. If this address is close to zero, it usually means that the application has attempted to access a
member of a structure, but the pointer to the structure is NULL. If this address is something else (garbage
value, not in 0x3fxxxxxx - 0x6xxxxxxx range), it likely means that the pointer used to access the data is
either not initialized or has been corrupted.
I use ESP32 with 4MB flash and platformio.
I use 8.3.4.
I want to let it work correctly.
    lv_indev_drv_t indev_drv;
    indev_drv.type = LV_INDEV_TYPE_ENCODER;
    indev_drv.read_cb = drv_read_handler;
I will appreciate any help too much!
