PLATFORM: Espressif 32 (3.4.0) > DOIT ESP32 DEVKIT V1
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
Dependency Graph
|-- lvgl 8.1.0
| |-- ESP32 BLE Arduino 1.0.1
|-- LovyanGFX 0.4.10
| |-- SPI 1.0
| |-- Wire 1.0.1
|-- SD(esp32) 1.0.5
| |-- FS 1.0
| |-- SPI 1.0
|-- SPI 1.0
In a FreeRTOS task, BMP images are read one after the other from the SD card and displayed on the current screen. The BMP images are 100 X 100 pixels with a bit depth of 16 and have a file size of approximately 20KB. It takes a long time (about 1.1 seconds) to read and display a single image. I wrote a test program which reads 40 * 512 bytes in 0.126 seconds via the SD library.
An image is initially read with 3 * 54 bytes and then read in in approximately 50 increments of 200 bytes each, then the file is closed and then reopened and then 2 * 54 and 50 * 200 bytes are read until the complete image is read.
Question: Is there a way to increase the 200 bytes to 512 bytes and if so, how.
Many thanks for the help.
There was a PR that meant to fix it but it was closed due to inactivity.
It seemed almost ready and i’d be great a to finish it. Are you interested in helping with it?
Yes, I would like to help. What do you expect from me?
Great!
The PR I mentioned seems like a good starting point. Please create a new PR based on the existing one.
I had a few minor comments in the original PR that should be fixed.
And the result should be tested.
The changes to the three files of the PR 2401 from PGNetHun are merged manually in my LVGL fork. Unfortunately the flag enable_cache is not set anywhere. This means that the new function lv_fs_read_cached is never called.
For test purposes I have set the flags f.drv-> enable_cache = true; and f.drv-> cache_size = 512; in the file lv_bmp.c in the function decoder_info so that the new function lv_fs_read_cached is called in the file misc / lv_fs.c. Then the system crashed in the new function lv_fs_read_cached with the instructionuint32_t file_position = file_p-> cache-> file_position;because the cache structure is probably not initialized correctly.
Question: where and how must the cache structure lv_fs_file_cache_t be correctly initialized based on lv_conf.h.
Thanks for looking into this!
Pleas send a PR with the current state. It’s much easier discuss it on GitHub.
I have created the PR 2979
