NUC977
I want to make button state draw quickly.(In fact i want to improve the lvgl running preference)
I try to use lvgl 6.0.1 and use default theme.It’s quickly when I press the big button.(Button Size 250*50).
But it’s slow in lvgl 7.10.0.I use the same code to test.I can see the draw by eyes at 7.10.0version.
and ```
tags:
lv_obj_t *homeCont;
lv_obj_t *btn, *label;
homeCont = lv_obj_create(lv_scr_act(), NULL);
lv_obj_set_size(homeCont, 800, 480);
lv_obj_set_pos(homeCont, 0, 0);
btn = lv_btn_create(homeCont, NULL);
lv_obj_set_size(btn, 200, 250);
lv_obj_set_pos(btn, 300, 140);
label = lv_label_create(btn, NULL);
lv_label_set_text(label, "Espresso");
