Hi everyone,
I bought a dev. kit with IMXRT1170 but it is supported for v7.11, my application with V8.1 so updated it. However, it’s running correctly when its full refresh is enabled, otherwise, the screen is mixed. What could be causing the problem?
Does anyone have any suggestions?
Please check the init code, where is wrong?
I guess that must be revised in flush callback function.
* Copyright 2019-2021 NXP
* All rights reserved.
* SPDX-License-Identifier: BSD-3-Clause
#include "littlevgl_support.h"
#include "lvgl.h"
#if defined(SDK_OS_FREE_RTOS)
#include "FreeRTOS.h"
#include "semphr.h"
#include "board.h"
#include "fsl_gpio.h"
#include "fsl_cache.h"
#include "fsl_debug_console.h"
#include "fsl_gt911.h"
#if LV_USE_GPU && LV_USE_GPU_NXP_PXP
#include "src/gpu/lv_gpu_nxp_pxp.h"
#include "src/gpu/lv_gpu_nxp_pxp_osa.h"
#if LV_USE_GPU && LV_USE_GPU_NXP_VG_LITE
#include "vg_lite.h"
#include "vg_lite_platform.h"
* Definitions
/* Cache line size. */
#ifndef FSL_FEATURE_L2CACHE_LINESIZE_BYTE
#define FSL_FEATURE_L2CACHE_LINESIZE_BYTE 0
#ifndef FSL_FEATURE_L1DCACHE_LINESIZE_BYTE
#define FSL_FEATURE_L1DCACHE_LINESIZE_BYTE 0
#if (FSL_FEATURE_L2CACHE_LINESIZE_BYTE > FSL_FEATURE_L1DCACHE_LINESIZE_BYTE)
#define DEMO_CACHE_LINE_SIZE FSL_FEATURE_L2CACHE_LINESIZE_BYTE
#else
#define DEMO_CACHE_LINE_SIZE FSL_FEATURE_L1DCACHE_LINESIZE_BYTE
#if (DEMO_CACHE_LINE_SIZE > FRAME_BUFFER_ALIGN)
#define DEMO_FB_ALIGN DEMO_CACHE_LINE_SIZE
#else
#define DEMO_FB_ALIGN FRAME_BUFFER_ALIGN
#if (LV_ATTRIBUTE_MEM_ALIGN_SIZE > DEMO_FB_ALIGN)
#undef DEMO_FB_ALIGN
#define DEMO_FB_ALIGN LV_ATTRIBUTE_MEM_ALIGN_SIZE
#define DEMO_FB_SIZE \
(((DEMO_BUFFER_WIDTH * DEMO_BUFFER_HEIGHT * LCD_FB_BYTE_PER_PIXEL) + DEMO_FB_ALIGN - 1) & ~(DEMO_FB_ALIGN - 1))
#define VG_LITE_MAX_CONTIGUOUS_SIZE 0x200000
#define VG_LITE_COMMAND_BUFFER_SIZE (256 << 10)
* Prototypes
static void DEMO_FlushDisplay(lv_disp_drv_t *disp_drv, const lv_area_t *area, lv_color_t *color_p);
#if LV_USE_GPU
static void DEMO_CleanInvalidateCache(lv_disp_drv_t *disp_drv);
static void DEMO_InitTouch(void);
static bool DEMO_ReadTouch(lv_indev_drv_t *drv, lv_indev_data_t *data);
static void DEMO_BufferSwitchOffCallback(void *param, void *switchOffBuffer);
static void BOARD_PullMIPIPanelTouchResetPin(bool pullUp);
static void BOARD_ConfigMIPIPanelTouchIntPin(gt911_int_pin_mode_t mode);
static status_t BOARD_PrepareVGLiteController(void);
static status_t BOARD_InitVGliteClock(void);
#endif /* LV_USE_GPU_NXP_VG_LITE */
* Variables
SDK_ALIGN(static uint8_t s_frameBuffer[2][DEMO_FB_SIZE], DEMO_FB_ALIGN);
static SemaphoreHandle_t s_transferDone;
#else
static volatile bool s_transferDone;
static gt911_handle_t s_touchHandle;
static const gt911_config_t s_touchConfig = {
.I2C_SendFunc = BOARD_MIPIPanelTouch_I2C_Send,
.I2C_ReceiveFunc = BOARD_MIPIPanelTouch_I2C_Receive,
.pullResetPinFunc = BOARD_PullMIPIPanelTouchResetPin,
.intPinFunc = BOARD_ConfigMIPIPanelTouchIntPin,
.timeDelayMsFunc = VIDEO_DelayMs,
.touchPointNum = 1,
.i2cAddrMode = kGT911_I2cAddrMode0,
.intTrigMode = kGT911_IntRisingEdge,
static int s_touchResolutionX;
static int s_touchResolutionY;
static lv_disp_drv_t disp_drv; /*Descriptor of a display driver*/
static uint32_t registerMemBase = 0x41800000;
static uint32_t gpu_mem_base = 0x0;
* In case custom VGLite memory parameters are used, the application needs to
* allocate and publish the VGLite heap base, its size and the size of the
* command buffer(s) using the following global variables:
extern void *vglite_heap_base;
extern uint32_t vglite_heap_size;
extern uint32_t vglite_cmd_buff_size;
#if (CUSTOM_VGLITE_MEMORY_CONFIG == 0)
/* VGLite driver heap */
AT_NONCACHEABLE_SECTION_ALIGN(static uint8_t vglite_contiguous_mem[VG_LITE_MAX_CONTIGUOUS_SIZE], 64);
void *vglite_heap_base = &vglite_contiguous_mem;
uint32_t vglite_heap_size = VG_LITE_MAX_CONTIGUOUS_SIZE;
uint32_t vglite_cmd_buff_size = VG_LITE_COMMAND_BUFFER_SIZE;
#endif /* CUSTOM_VGLITE_MEMORY_CONFIG */
* Code
void lv_port_pre_init(void)
void lv_port_disp_init(void)
memset(s_frameBuffer, 0, sizeof(s_frameBuffer));
lv_disp_draw_buf_init(&disp_buf, s_frameBuffer[0], s_frameBuffer[1], LV_HOR_RES_MAX * LV_VER_RES_MAX);
status_t status;
dc_fb_info_t fbInfo;
/* Initialize GPU. */
BOARD_PrepareVGLiteController();
* Initialize your display
BOARD_PrepareDisplayController();
status = g_dc.ops->init(&g_dc);
if (kStatus_Success != status)
assert(0);
g_dc.ops->getLayerDefaultConfig(&g_dc, 0, &fbInfo);
fbInfo.pixelFormat = DEMO_BUFFER_PIXEL_FORMAT;
fbInfo.width = DEMO_BUFFER_WIDTH;
fbInfo.height = DEMO_BUFFER_HEIGHT;
fbInfo.startX = DEMO_BUFFER_START_X;
fbInfo.startY = DEMO_BUFFER_START_Y;
fbInfo.strideBytes = DEMO_BUFFER_STRIDE_BYTE;
g_dc.ops->setLayerConfig(&g_dc, 0, &fbInfo);
g_dc.ops->setCallback(&g_dc, 0, DEMO_BufferSwitchOffCallback, NULL);
s_transferDone = xSemaphoreCreateBinary();
if (NULL == s_transferDone)
PRINTF("Frame semaphore create failed\r\n");
assert(0);
#else
s_transferDone = false;
/* littlevgl starts render in frame buffer 0, so show frame buffer 1 first. */
g_dc.ops->setFrameBuffer(&g_dc, 0, (void *)s_frameBuffer[1]);
/* Wait for frame buffer sent to display controller video memory. */
if ((g_dc.ops->getProperty(&g_dc) & kDC_FB_ReserveFrameBuffer) == 0)
if (xSemaphoreTake(s_transferDone, portMAX_DELAY) != pdTRUE)
PRINTF("Wait semaphore error: s_transferDone\r\n");
assert(0);
#else
while (false == s_transferDone)
g_dc.ops->enableLayer(&g_dc, 0);
disp_drv.hor_res = LV_HOR_RES_MAX;
disp_drv.ver_res = LV_VER_RES_MAX;
//disp_drv.full_refresh = 1;
disp_drv.flush_cb = DEMO_FlushDisplay;
#if LV_USE_GPU
disp_drv.clean_dcache_cb = DEMO_CleanInvalidateCache;
/*Set a display buffer*/
lv_gpu_nxp_pxp_init(&pxp_default_cfg);
if (vg_lite_init(64, 64) != VG_LITE_SUCCESS) {
PRINTF("VGLite init error. STOP.");
vg_lite_close();
assert(0);
BaseType_t taskAwake = pdFALSE;
xSemaphoreGiveFromISR(s_transferDone, &taskAwake);
portYIELD_FROM_ISR(taskAwake);
#else
s_transferDone = true;
#if LV_USE_GPU
#if __CORTEX_M == 4
L1CACHE_CleanInvalidateSystemCache();
#else
SCB_CleanInvalidateDCache();
#if !defined(SDK_OS_FREE_RTOS)
DCACHE_CleanInvalidateByRange((uint32_t)color_p, DEMO_FB_SIZE);
g_dc.ops->setFrameBuffer(&g_dc, 0, (void *)color_p);
if (xSemaphoreTake(s_transferDone, portMAX_DELAY) == pdTRUE)
/* IMPORTANT!!!
PRINTF("Display flush failed\r\n");
assert(0);
#else
/* IMPORTANT!!!
void lv_port_indev_init(void)
#if IS_TOUCH_SUPPORTED()
lv_indev_drv_t indev_drv;
* Touchpad
/*Initialize your touchpad */
DEMO_InitTouch();
indev_drv.read_cb = DEMO_ReadTouch;
#else
// The chosen display does not have touch support
if (pullUp)
GPIO_PinWrite(BOARD_MIPI_PANEL_TOUCH_RST_GPIO, BOARD_MIPI_PANEL_TOUCH_RST_PIN, 1);
GPIO_PinWrite(BOARD_MIPI_PANEL_TOUCH_RST_GPIO, BOARD_MIPI_PANEL_TOUCH_RST_PIN, 0);
if (mode == kGT911_IntPinInput)
BOARD_MIPI_PANEL_TOUCH_INT_GPIO->GDIR &= ~(1UL << BOARD_MIPI_PANEL_TOUCH_INT_PIN);
if (mode == kGT911_IntPinPullDown)
GPIO_PinWrite(BOARD_MIPI_PANEL_TOUCH_INT_GPIO, BOARD_MIPI_PANEL_TOUCH_INT_PIN, 0);
GPIO_PinWrite(BOARD_MIPI_PANEL_TOUCH_INT_GPIO, BOARD_MIPI_PANEL_TOUCH_INT_PIN, 1);
BOARD_MIPI_PANEL_TOUCH_INT_GPIO->GDIR |= (1UL << BOARD_MIPI_PANEL_TOUCH_INT_PIN);
/*Initialize your touchpad*/
status_t status;
const gpio_pin_config_t resetPinConfig = {
.direction = kGPIO_DigitalOutput, .outputLogic = 0, .interruptMode = kGPIO_NoIntmode};
GPIO_PinInit(BOARD_MIPI_PANEL_TOUCH_INT_GPIO, BOARD_MIPI_PANEL_TOUCH_INT_PIN, &resetPinConfig);
GPIO_PinInit(BOARD_MIPI_PANEL_TOUCH_RST_GPIO, BOARD_MIPI_PANEL_TOUCH_RST_PIN, &resetPinConfig);
status = GT911_Init(&s_touchHandle, &s_touchConfig);
PRINTF("Touch IC initialization failed\r\n");
assert(false);
GT911_GetResolution(&s_touchHandle, &s_touchResolutionX, &s_touchResolutionY);
/* Will be called by the library to read the touchpad */
static int touch_x = 0;
static int touch_y = 0;
if (kStatus_Success == GT911_GetSingleTouch(&s_touchHandle, &touch_x, &touch_y))
data->point.x = touch_x * DEMO_PANEL_WIDTH / s_touchResolutionX;
data->point.y = touch_y * DEMO_PANEL_HEIGHT / s_touchResolutionY;
/*Return `false` because we are not buffering and no more data to read*/
return false;
void GPU2D_IRQHandler(void)
vg_lite_IRQHandler();
const clock_root_config_t gc355ClockConfig = {
.clockOff = false,
.mux = kCLOCK_GC355_ClockRoot_MuxVideoPllOut,
.div = 2,
CLOCK_SetRootClock(kCLOCK_Root_Gc355, &gc355ClockConfig);
CLOCK_GetRootClockFreq(kCLOCK_Root_Gc355);
CLOCK_EnableClock(kCLOCK_Gpu2d);
NVIC_SetPriority(GPU2D_IRQn, 3);
EnableIRQ(GPU2D_IRQn);
return kStatus_Success;
status_t status;
status = BOARD_InitVGliteClock();
return status;
vg_lite_init_mem(registerMemBase, gpu_mem_base, vglite_heap_base, vglite_heap_size);
vg_lite_set_command_buffer_size(vglite_cmd_buff_size);
