Improving CPU usage / Screen tear
STM32F767ZI - STM32DUINO PlatformIO
V8.3
I am using FMC with SSD1963 7" display (800 x 480) but it is suffering badly with screen tear when for instance scrolling or displaying images.
Would DMA2D improve the performance and is there any guidance on this, the documentation is currently TODO?
I am unsure how to use the built-in DMA2D within LVGL, I can see once enabled it should initialise it all but how do I incorporate that within my disp_flush: I have had a look at lv_gpu_stm32_dma2d.c but it looks to me like this is all handled by LVGL?
I attempted with using basic DMA referring back to examples and documentation, as I have done with FMC but I am getting display corruption where the horizontal lines are not lined up.
I am using Bank1 FMC SDRAM and the region is:
CommandAccess
*(uint16_t*)((uint32_t)0xC0000000)
DataAccess
*(uint16_t*)((uint32_t)0xC0080000)
DMA2D
lv_conf.h
/*Use STM32's DMA2D (aka Chrom Art) GPU*/
#define LV_USE_GPU_STM32_DMA2D 1
#if LV_USE_GPU_STM32_DMA2D
/*Must be defined to include path of CMSIS header of target processor
e.g. "stm32f7xx.h" or "stm32f4xx.h"*/
#define LV_GPU_DMA2D_CMSIS_INCLUDE "stm32f7xx.h"
my_disp_flush
static void my_disp_flush(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p)
int32_t x, y;
/***create a working window***/
*(uint16_t*)((uint32_t)0xC0000000) = (0x2a); //CommandAccess
*(uint16_t*)((uint32_t)0xC0080000) = (area->x1 >> 8); //DataAccess
*(uint16_t*)((uint32_t)0xC0080000) = (area->x1 & 0xFF); //DataAccess
*(uint16_t*)((uint32_t)0xC0080000) = (area->x2 >> 8); //DataAccess
*(uint16_t*)((uint32_t)0xC0080000) = (area->x2 & 0xFF); //DataAccess
*(uint16_t*)((uint32_t)0xC0000000) = (0x2b); //CommandAccess
*(uint16_t*)((uint32_t)0xC0080000) = (area->y1 >> 8); //DataAccess
*(uint16_t*)((uint32_t)0xC0080000) = (area->y1 & 0xFF); //DataAccess
*(uint16_t*)((uint32_t)0xC0080000) = (area->y2 >> 8); //DataAccess
*(uint16_t*)((uint32_t)0xC0080000) = (area->y2 & 0xFF); //DataAccess
*(uint16_t*)((uint32_t)0xC0000000) = (0x2c); //CommandAccess
for (int y = area->y1; y <= area->y2; y++) {
for (int x = area->x1; x <= area->x2; x++) {
*(uint16_t*)((uint32_t)0xC0080000) = color_p->full; //DataAccess
//*(uint16_t*)((uint32_t)0xC0080000) = (*color_p); //DataAccess
color_p++;
lv_disp_flush_ready(disp); // tell lvgl that flushing is done
Manually trying DMA
init_dma
void init_dma(void) {
__HAL_RCC_DMA2_CLK_ENABLE();
hdma_memtomem.Instance = DMA2_Stream0;
hdma_memtomem.Init.Channel = DMA_CHANNEL_0;
hdma_memtomem.Init.Direction = DMA_MEMORY_TO_MEMORY;
hdma_memtomem.Init.PeriphInc = DMA_PINC_ENABLE;
hdma_memtomem.Init.MemInc = DMA_MINC_ENABLE;
hdma_memtomem.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
hdma_memtomem.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
hdma_memtomem.Init.Mode = DMA_NORMAL;
hdma_memtomem.Init.Priority = DMA_PRIORITY_LOW;
hdma_memtomem.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
HAL_DMA_Init(&hdma_memtomem);
transfer_data_dma
void transfer_data_dma(uint16_t *src, uint16_t *dest, uint32_t size) {
// Configure DMA for memory-to-memory transfer
hdma_memtomem.Init.Mode = DMA_CIRCULAR;
// Set source and destination addresses and size
hdma_memtomem.Instance->PAR = (uint32_t)src;
hdma_memtomem.Instance->M0AR = (uint32_t)dest;
hdma_memtomem.Instance->NDTR = size;
// Enable DMA transfer
HAL_DMA_Start(&hdma_memtomem, (uint32_t)src, (uint32_t)dest, size);
my_disp_flush_dma
static void my_disp_flush_dma(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p)
SCB_CleanInvalidateDCache();
// Set the draw area (if needed)
// Use DMA to transfer pixel data to the display
//transfer_data_dma((uint16_t *)color_p, (uint16_t*)((uint32_t)0xC0080000), (area->x2 - area->x1 + 1) * (area->y2 - area->y1 + 1));
uint32_t pixel_count = (area->x2 - area->x1 + 1) * (area->y2 - area->y1 + 1);
transfer_data_dma((uint16_t *)color_p, (uint16_t*)((uint32_t)0xC0080000), pixel_count);
color_p += pixel_count;
Video
See attached Video.zip
Video.zip (3.3 MB)
Thanks in advance
