Image split in half when angle was set
a cortex m4 mcu, with 128M freq and 396k ram
v7.11
the second hand break into 2 parts when it moves, especially in 9 direction and 4 direction. the upper part moves first and the other follows.
i wonder if the cpu is too slow and could not render whole area in certain time.
delete all other elements, set longer period for the timer。
LV_IMG_DECLARE(symf2hr);
LV_IMG_DECLARE(symf2mn);
LV_IMG_DECLARE(symf2sec);
static lv_task_t *timer;
static lv_obj_t *imghour, *imgmin, *imgsec;
void init(void)
    struct tm tmcur;
    datetime_current(&tmcur);
    imghour = lv_img_create(lv_scr_act(), NULL);
    lv_img_set_src(imghour, &symf2hr);
    lv_img_set_pivot(imghour, 16, 108);
    lv_img_set_angle(imghour, tmcur.tm_hour * 300 + tmcur.tm_min * 5);
    lv_obj_align(imghour, NULL, LV_ALIGN_IN_TOP_MID, 0, 180 - 108);
    imgmin = lv_img_create(lv_scr_act(), NULL);
    lv_img_set_src(imgmin, &symf2mn);
    lv_img_set_pivot(imgmin, 8, 157);
    lv_img_set_angle(imgmin, tmcur.tm_min * 60 + tmcur.tm_sec);
    lv_obj_align(imgmin, NULL, LV_ALIGN_IN_TOP_MID, 0, 180 - 157);
    imgsec = lv_img_create(lv_scr_act(), NULL);
    lv_img_set_src(imgsec, &symf2sec);
    lv_img_set_pivot(imgsec, 7, 159);
    lv_img_set_angle(imgsec, tmcur.tm_sec * 60);
    lv_obj_align(imgsec, NULL, LV_ALIGN_IN_TOP_MID, 0, 180 - 159);
    timer = lv_task_create(timer_cb, 400, LV_TASK_PRIO_HIGH,NULL);
void timer_cb(lv_task_t *task)
    struct tm tmcur;
btw, lcd size 360360, second hand image size 13195, convert format CF_TRUE_COLOR_ALPHA
