I try to change images every 3 seconds. I use the “lv_task_create(vfn_img_change, 3000, LV_TASK_PRIO_MID, NULL);” to achieve that. However, the memory increased and out of range finally. How to release memory in change another image?
I using eclipse to run pc_simulator.
Thanks.
/You code here/
static lv_obj_t *img2;
void demo_create(void)
lv_obj_t *wp;
wp = lv_img_create(lv_disp_get_scr_act(NULL), NULL);
lv_img_set_src(wp, &back);
lv_obj_set_protect(wp, LV_PROTECT_POS);
void vfn_img_change(void *p)
if(!imgIndex)
vfn_card();
vfn_image();
void vfn_card()
img2 = lv_img_create(lv_scr_act(), NULL);
lv_img_set_src(img2, &card);
lv_obj_set_drag(img2, true);
void vfn_image()
lv_img_set_src(img2, &battery);
