I am trying to render a simple image on one of my SSD1306. It works when I am passing text or a symbol, but only renders a blank screen when I pass the image as a variable, as described in the tutorial. If it helps, I am using ZMK since the display I am trying to render to is on a keyboard.
nRF52840
v8.4. This is because ZMK is built with this version.
Make the screen show a simple 7x7 image. Or any image whatsoever.
I tried passing a symbol or text as the image source: this works. Then, I also tried to pass an image variable as described in the tutorial. I tried different encodings from the converter, but to no avail.
#ifndef LV_ATTRIBUTE_MEM_ALIGN
#define LV_ATTRIBUTE_MEM_ALIGN
#ifndef LV_ATTRIBUTE_IMG_STUPIDIMAGE
#define LV_ATTRIBUTE_IMG_STUPIDIMAGE
const LV_ATTRIBUTE_MEM_ALIGN LV_ATTRIBUTE_LARGE_CONST LV_ATTRIBUTE_IMG_STUPIDIMAGE uint8_t stupidimage_map[] = {
#if LV_COLOR_DEPTH == 1 || LV_COLOR_DEPTH == 8
/*Pixel format: Red: 3 bit, Green: 3 bit, Blue: 2 bit*/
0xb7, 0xb7, 0xb7, 0xff, 0xb7, 0xb7, 0xb7,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
#if LV_COLOR_DEPTH == 16 && LV_COLOR_16_SWAP == 0
/*Pixel format: Red: 5 bit, Green: 6 bit, Blue: 5 bit*/
0xa5, 0x96, 0xa5, 0x96, 0xa5, 0x96, 0xff, 0xdf, 0xa5, 0x96, 0xa5, 0x96, 0xa5, 0x96,
0xff, 0xdf, 0xff, 0xdf, 0xff, 0xdf, 0xff, 0xdf, 0xff, 0xdf, 0xff, 0xdf, 0xff, 0xdf,
#if LV_COLOR_DEPTH == 16 && LV_COLOR_16_SWAP != 0
/*Pixel format: Red: 5 bit, Green: 6 bit, Blue: 5 bit BUT the 2 bytes are swapped*/
0x96, 0xa5, 0x96, 0xa5, 0x96, 0xa5, 0xdf, 0xff, 0x96, 0xa5, 0x96, 0xa5, 0x96, 0xa5,
0xdf, 0xff, 0xdf, 0xff, 0xdf, 0xff, 0xdf, 0xff, 0xdf, 0xff, 0xdf, 0xff, 0xdf, 0xff,
#if LV_COLOR_DEPTH == 32
/*Pixel format: Fix 0xFF: 8 bit, Red: 8 bit, Green: 8 bit, Blue: 8 bit*/
0xa2, 0xae, 0xb2, 0xff, 0xa2, 0xae, 0xb2, 0xff, 0xa2, 0xae, 0xb2, 0xff, 0xf9, 0xf6, 0xfa, 0xff, 0xa2, 0xae, 0xb2, 0xff, 0xa2, 0xae, 0xb2, 0xff, 0xa2, 0xae, 0xb2, 0xff,
0xfc, 0xf6, 0xfa, 0xff, 0xf5, 0xf6, 0xfa, 0xff, 0xf5, 0xf6, 0xfa, 0xff, 0xf9, 0xf6, 0xfa, 0xff, 0xf5, 0xf6, 0xfa, 0xff, 0xf5, 0xf6, 0xfa, 0xff, 0xf5, 0xf6, 0xfa, 0xff,
const lv_img_dsc_t stupidimage = {
.header.cf = LV_IMG_CF_TRUE_COLOR,
.header.always_zero = 0,
.header.reserved = 0,
.header.w = 7,
.header.h = 7,
.data_size = 49 * LV_COLOR_SIZE / 8,
.data = stupidimage_map,
int zmk_widget_image_init(struct zmk_widget_image *widget, lv_obj_t *parent) {
LV_IMG_DECLARE(stupidimage);
widget->obj = lv_img_create(parent);
lv_img_set_src(widget->obj, &stupidimage);
// lv_img_set_src(widget->obj, LV_SYMBOL_DUMMY "Some text");
sys_slist_append(&widgets, &widget->node);
widget_image_init();
return 0;
static struct zmk_widget_image image_widget;
lv_obj_t *zmk_display_status_screen() {
lv_obj_t *screen;
screen = lv_obj_create(NULL);
zmk_widget_image_init(&image_widget, screen);
lv_obj_align(zmk_widget_image_obj(&image_widget), LV_ALIGN_CENTER, 0, 0);
lv_obj_set_size(zmk_widget_image_obj(&image_widget), 32, 32);
return screen;
There is just a blank box over the display elements.
