Image button from Filesystem issue
I need to use image button through littlevgl filesystem. It reads the image from the spiffs, but a “No” word appears in the top of the image when i press it.
ESP32 on Arduino IDE
An image button without the “No” word.
The drive implementation:
void spiffs_drv_init(){
  lv_fs_drv_init(&drv);                     /*Basic initialization*/
  drv.letter = 'D';                         /*An uppercase letter to identify the drive */
  drv.file_size = sizeof(File);   /*Size required to store a file object*/
  //drv.rddir_size = sizeof(my_dir_object);   /*Size required to store a directory object (used by dir_open/close/read)*/
  //drv.ready_cb = my_ready_cb;               /*Callback to tell if the drive is ready to use */
  drv.open_cb = my_open_cb;                 /*Callback to open a file */
  drv.close_cb = my_close_cb;               /*Callback to close a file */
  drv.remove_cb = my_remove_cb;             /*Callback to remove a file */
  drv.read_cb = my_read_cb;                 /*Callback to read a file */
  drv.write_cb = my_write_cb;               /*Callback to write a file */
  drv.seek_cb = my_seek_cb;                 /*Callback to seek in a file (Move cursor) */
  drv.tell_cb = my_tell_cb;                 /*Callback to tell the cursor position  */
  //drv.size_cb = my_size_cb;                 /*Callback to tell a file's size */
  //drv.rename_cb = my_size_cb;               /*Callback to rename a file */
  //drv.dir_open_cb = my_dir_open_cb;         /*Callback to open directory to read its content */
  //drv.dir_read_cb = my_dir_read_cb;         /*Callback to read a directory's content */
  //drv.dir_close_cb = my_dir_close_cb;       /*Callback to close a directory */
  //drv.free_space_cb = my_size_cb;           /*Callback to tell free space on the drive */
  //drv.user_data = my_user_data;             /*Any custom data if required*/
  lv_fs_drv_register(&drv);                 /*Finally register the drive*/
lv_fs_res_t my_open_cb(lv_fs_drv_t *drv, void *file_p, const char *fn, lv_fs_mode_t mode){
  (void) drv; /*Unused*/
  if (f) {
    return LV_FS_RES_OK;
  char buf[100];
  sprintf(buf,"/%s",fn);
  f = SPIFFS.open(buf, mode == LV_FS_MODE_WR ? FILE_WRITE : FILE_READ);
  if(!f || f.isDirectory()){
    return LV_FS_RES_UNKNOWN;
  } else{
lv_fs_res_t my_close_cb(lv_fs_drv_t *drv, void *file_p){
  f.close();
lv_fs_res_t my_read_cb(lv_fs_drv_t *drv, void *file_p,
                        void *buf, uint32_t btr, uint32_t *br){
  *br = f.read((uint8_t*)buf, btr);
  Serial.println("READ");
lv_fs_res_t my_write_cb(lv_fs_drv_t *drv, void *file_p,
                        const void *buf, uint32_t btw, uint32_t *bw){
  *bw = f.write((const uint8_t*)buf, btw);
lv_fs_res_t my_seek_cb(lv_fs_drv_t *drv, void *file_p, uint32_t pos){
  f.seek(pos);
lv_fs_res_t my_tell_cb(lv_fs_drv_t *drv, void *file_p, uint32_t *pos_p){
  uint32_t tmp = f.position();
  pos_p = &tmp;
lv_fs_res_t my_remove_cb(lv_fs_drv_t *drv, const char *fn){
  char buf[100];
  if(SPIFFS.remove(buf)){
  } else{
Image button implementation:
lv_style_copy(&style_upper_bar, &lv_style_scr);
  style_upper_bar.body.main_color = LV_COLOR_BLACK;
  style_upper_bar.body.grad_color = LV_COLOR_BLACK;
  style_upper_bar.body.opa = LV_OPA_50;
  lv_style_copy(&style_img_pr, &lv_style_plain);
  style_img_pr.image.color = LV_COLOR_BLACK;
  style_img_pr.image.intense = LV_OPA_50;
  style_img_pr.text.color = lv_color_hex3(0xaaa);
  // Home button on the left side bar
  lv_obj_t *test = lv_imgbtn_create(scr, NULL);
  lv_imgbtn_set_src(test, LV_BTN_STATE_PR, "D:/background_small.bin");
  lv_imgbtn_set_src(test, LV_BTN_STATE_REL, "D:/background_small.bin");
  lv_imgbtn_set_src(test, LV_BTN_STATE_TGL_PR, "D:/background_small.bin");
  lv_imgbtn_set_src(test, LV_BTN_STATE_TGL_REL, "D:/background_small.bin");
  lv_imgbtn_set_src(test, LV_BTN_STATE_INA, "D:/background_small.bin");
  lv_imgbtn_set_style(test, LV_BTN_STATE_PR, &style_img_pr);
  lv_imgbtn_set_style(test, LV_BTN_STATE_TGL_PR, &style_img_pr);
  lv_imgbtn_set_toggle(test, true);
  lv_obj_align(test, NULL, LV_ALIGN_CENTER, 10, 0);
  lv_btn_set_state(test, LV_BTN_STATE_TGL_REL);
  //lv_btn_set_ink_in_time(test, 100);
This is the video dimostrating the problem.
Being discussed here:
