Image background
I’m testing the library, I add one image .png to a tft display, this image hasn’t background but when I display the image in the tft, it has a black background. I use the online images converter from LVGL, later I add the .c file into the lvgl-master/src
ESP32 with ILI9341 display
v.7
Display the images with background transparent
Convert the image in .png format without background in a .c file image with the LVGL online images converter
#include <lvgl.h>
#include <TFT_eSPI.h>
#if USE_LV_LOG != 0
/* Serial debugging */
void my_print(lv_log_level_t level, const char * file, uint32_t line, const char * dsc)
    Serial.printf("%s@%d->%s\r\n", file, line, dsc);
    Serial.flush();
/* Display flushing */
    tft.startWrite();
    tft.pushColors(&color_p->full, w * h, true);
    tft.endWrite();
    lv_disp_flush_ready(disp);
/* Reading input device (simulated encoder here) */
bool read_encoder(lv_indev_drv_t * indev, lv_indev_data_t * data)
    static int32_t last_diff = 0;
    int32_t diff = 0; /* Dummy - no movement */
    int btn_state = LV_INDEV_STATE_REL; /* Dummy - no press */
    data->enc_diff = diff - last_diff;;
    data->state = btn_state;
    last_diff = diff;
    return false;
void setup()
    pinMode(15, OUTPUT);
    digitalWrite(15, LOW);
    delay(1);
#if USE_LV_LOG != 0
    lv_log_register_print_cb(my_print); /* register print function for debugging */
    tft.begin(); /* TFT init */
    tft.setRotation(1); /* Landscape orientation */
    lv_disp_buf_init(&disp_buf, buf, NULL, LV_HOR_RES_MAX * 10);
    /*Initialize the display*/
    lv_disp_drv_t disp_drv;
    lv_disp_drv_init(&disp_drv);
    disp_drv.hor_res = 320;
    disp_drv.ver_res = 240;
    disp_drv.buffer = &disp_buf;
    lv_indev_drv_t indev_drv;
    indev_drv.type = LV_INDEV_TYPE_ENCODER;
    indev_drv.read_cb = read_encoder;
   LV_IMG_DECLARE(logo);
  lv_obj_t * img_src = lv_img_create(lv_scr_act(), NULL); /*Crate an image object*/
  lv_img_set_src(img_src, &logo);  /*Set the created file as image (a red fl  ower)*/
  lv_obj_set_pos(img_src, 0, 0);      /*Set the positions*/
  lv_obj_set_drag(img_src, true);
void loop()
    delay(5);
Did you convert the image using “True color with alpha”? If alpha is not included, the image will have a background added to it.
Hi Alvaro,
You can try adding style to the object.
static lv_style_t style;
lv_style_init(&style);
lv_style_set_bg_opa(&style, LV_STATE_DEFAULT, LV_OPA_TRANSP);
lv_style_set_bg_color(&style, LV_STATE_DEFAULT, LV_COLOR_SILVER);
 lv_img_set_src(img_src, &logo);  /*Set the created file as image (a red flower)*/
 lv_obj_add_style(img_src, LV_OBJ_PART_MAIN, &style);
You can even consider adding lv_style_set_border_opa(), lv_style_set_border_color() if needed. Description about how to use if provided in their documentation under Styles section
thank you
I didn’t select true color with alpha, now it works, thanks!
cool glad it worked
