I know that the SVG support is difficult, and could required an SVG renderer. I think what I’m looking for is a way to bring in an SVG image, then specify the size that I want to use. Here’s the problem use-case that I faced:
need to add a settings icon to my panel
I down load a copy from noun project. For some weird reason, the smallest size in 100x100.
I add the .png file to the assets folder
I assign to an image button
It’s way to big
I have no way to resize this in EdgeLine
I remove the image from the assets folder
I resize using other tools to 32x32
I re-add the image to the folder.
I re-assign the image to the image button
So SVG is a nice way around this - preserving the quality and converting to whatever size I need.
I hope this helps explain the reason for the request.
I see the problem and I agree that it’d be useful.
By “complicated” I meant it would requires a new panel or so in EdgeLine which needs careful design to be future proof. But something like this is definitely on the Roadmap however not for 1.0
